Ok. Confession my approach is coloured a by the nature of my sailing at 79yrs young I've had enough years of intense racing in proper lightweight racers, my Hanse with its heavy cargo of luxuries doesnt make me feel like racing? I cruise Solent and south coast down as far as Falmouth [sometimes]. Yes self tacking jib doesnt bring much to the party down wind, Hanse has a big mainsail, so I rig port and starboard lines for gybe preventors, they go through blocks on soft shackles at bow moorring cleats and back to cockpit, the gybe preventors lines have snap shackles which when needed clip onto a soft shackle on boom easily reached from cockpit. So dead downwind in wind F2 and above I roll up jib and use the main under safe control of a gybe preventor, I reef in the main as required for safe downwind sailing above F4? and usually before wind increases. Below F2 I do have a cruising chute, It is tacked to port or Stbd gybe preverntors, I occasionally us this, but in the confines of the Solent it is inconvienient due to the density of other vessels, so really only good for longer passages. It would be nice to try a code zero, but the expendature is hard to justify. To be realistic in light winds less F2 I am more that content to roll up jib, put the motor on and if the main is not contributing I drop in first reef, sheet amidships to damp any roll and get to next watering hole. I think many people put undue signifience to negatives of self tacking jib and forget the positives. If you need to keep crew engaged in fast racing tacks, you bought the wrong boat, relax with Hanse enjoy the convenience. I see Hanse owners obsessing about how big should the overlap be on a ST jib replacement Genoa, to get ultimate performance. Come on guys the brilliant big main with full length battens and single line reefing , a bendy mast full width traveler [mine has] gives great sail shape, good control, so learn to use it, Up wind the st jib and big main works brilliantly ---if you set it up correctly, dont sail the Hanse on its ear, keep her flat and play the shifts. Perry
