Main Sheet traveller
Forum Name: 370 / 375
URL: https://www.myhanse.com/forum_posts.asp?TID=14884
Topic: Main Sheet traveller
Posted By: Søren B. Petersen
Subject: Main Sheet traveller
Date Posted: 04 November 2024 at 19:54
I would like to upgrade the Lewmar size 1 (23 mm) traveller with a size 2 (30 mm) for next summer!
Can anyone tell me if the original traveller is:
- "Drilled" (Closed cross section) or
- "Sliding bolt track" (open cross section)
See sketch below!
I have my 2008 Hanse 370 in Italy, but live in Denmark!
Unfortunatle, I do not have a picture of the end of the track and only have difficult access to the boat, so if anyone can answer above question, I can order parts for next summer :-)
Thank you in advance
Best regards
Søren
Date Posted: 06 November 2024 at 19:48
Sorry I have realized (from an old bad photo), that it is likely a HD Beam track: H = 42 mm x W = 32 mm (see sketch) - if anyone can confirm that!
Thanks Søren
Posted By: Jens
Date Posted: 31 December 2024 at 10:15
Hi Søren
It is for sure a beam track. I measured the height of mine to 62 mm but I don’t find this size in the Lewmar catalogue. I’ll go to the boat soon and then I’ll check the measure. W at the top is 24 mm and I’ll also check the bottom with.
My boat is a 2008 model delivered in oct 07.
Jens
Jens
Hanse 370, #423, 2008
Three cabin
Posted By: Jef-370
Date Posted: 21 April 2025 at 13:45
I installed a 30 mm Selden mainsail track; it is not essential to stick with Lewmar...
https://servimg.com/view/12361977/1497" rel="nofollow">
