Wheel vibration
Forum Name: 505/508
URL: https://www.myhanse.com/forum_posts.asp?TID=14911
Topic: Wheel vibration
Posted By: Vitomita
Subject: Wheel vibration
Date Posted: 04 December 2024 at 07:38
Hello I am trying to buy an Hanse 505 2017, during sea trials I noticed a significant vibration on the wheel especially above 8 knots and 2400 rpm , the bottom and folding prop were just cleaned.
The wheel was vibration left and right about 15degrees and felt a lot of vibration through it, at 4 knots and with engine at idle the vibration stopped.
Is there an history of such a phenomena on the Hanse 505 ?
Thank you very much ,
I really appreciate any replies.
Posted By: SVZara
Date Posted: 06 December 2024 at 00:59
When I am pushing the engine 2500-3000rpm I get a slight vibration in the steering. I always assumed it was just prop wash over the rudder. It never concerned me.  I am not sure if you are talking about something else.
Marc
S/V Zara
2016 Hanse 505, Hull #129
Posted By: Vitomita
Date Posted: 06 December 2024 at 08:26
Unfortunately it’s more than a slight vibration, I will try to take a video next time, the bottom is clean as well as the 3 blade folding prop, the engine can’t pass 2800 rpm and smokes white a little, 1200 engine hours..
Posted By: FrankS
Date Posted: 06 December 2024 at 11:46
A friend of mine had the same problem with his Bavaria. In his case the engine mounts (engine supports?) were worn..
Hanse 345 2016 "STYX"
Posted By: ohthetrees
Date Posted: 15 March 2025 at 14:15
I feel a vibration in the wheel when motoring at higher speeds. However, there is no vibration when sailing at similar or even faster speeds. I conclude that it is turbulence from the propeller wash, and I'm not concerned.
