Telescopic davits
Forum Name: 460
URL: https://www.myhanse.com/forum_posts.asp?TID=14957
Topic: Telescopic davits
Posted By: Lhsrris218
Subject: Telescopic davits
Date Posted: 18 January 2025 at 17:58
Does anyone have an example of rigging the telescopic davits.  Where do you fix your lifting line.
Posted By: Typ2003
Date Posted: 22 January 2025 at 06:53
Hello, I was also curious.
https://youtu.be/D8N2Zp48lSs" rel="nofollow - https://youtu.be/D8N2Zp48lSs ? si=fynvTO-FkF2vKhEv
Separate clutch use
 I also buy telescopic Davits as an option.
Doesn't it include a clutch?
Date Posted: 22 January 2025 at 13:59
Curious how this Osculati davit supports the dinghy weight? If just by tightening two hinges attached to the stern, it doesn't look like a good idea. I got "Forespar" davit
https://youtu.be/K23N1XDMPyQ?si=n2Iu6iINXcZFJyuh
Works reasonably well, and the manufacturer states the allowed weight up to 350lb=160kg meaning you can hang both the dinghy and the outboard, at least in principleBig smile. Didnt try though, only carry dinghy which is about 40kg.
Date Posted: 22 January 2025 at 14:13
https://www.osculati.com/en/11623-42.358.00/small-telescopic-retractable-davit%20" rel="nofollow - https://www.osculati.com/en/11623-42.358.00/small-telescopic-retractable-davit
They seem to be able to support the weight.  I'm using a double sheeve block with simple reeve and it lifts quite well using the secondary winch.  There is no clutch or brake in line with this though.  Not sure where to mount a cleat.
Also wondering if I should add another block so the winch doesn't need to be used.  Wish hanse would have given some documentation on this.
Posted By: Axel1009
Date Posted: 26 January 2025 at 11:17
We have the telescopic davits that should carry 150kg, we use a carbon sail OC Tender on it that's 70kg and I wouldn't add a single kilo more, the installation is purely into the deck and if you are in a sea the deck slightly bends under the pressure.... I am currently working with the boat yard to strengthen these. As attachment I am running the line through to the aft cleats. There are the little clutches you get with it to run spring lines against the sideways movement.
Date Posted: 26 January 2025 at 11:25
Hi. Could you please send a picture of your setup.
Posted By: Axel1009
Date Posted: 26 January 2025 at 11:59
I'll take some and post here...
Posted By: Sahinsair
Date Posted: 07 May 2025 at 22:02
This davet is really very nice. I have 310 Highfield and 9.9 Suziki outboard engine. Ot has carried perfectly. But you need good set up and fix the boat closer to the boat with extra robes.
Sailing Sufi
Posted By: Typ2003
Date Posted: 12 October 2025 at 02:53
Separate clutch.
