Part Code for DC connectors
Forum Name: 415/418
URL: https://www.myhanse.com/forum_posts.asp?TID=14959
Topic: Part Code for DC connectors
Posted By: SYDNEY415
Subject: Part Code for DC connectors
Date Posted: 20 January 2025 at 04:00
I hope someone can help
I'm working on a Hanse 415 with TEV0986 DC Panel
I need to ad two more circuits but I cant find the part number for the DC connector plugs
Do you know what the part number is? Do you have them in stock
This is the main board that every accessory is connected through and fused (ie bilge)
Second question
The fusion stereo has blown an inline fuse, and cannot find its location, the 12V Yellow constant  & Red ignition wires  by pass the above fuse panel and head of to get power from a switched/constant power from somewhere. inline fuse in fusion loom is fine
Jason
Jason
Date Posted: 20 January 2025 at 13:14
Jason, you can order the grey/blue plugs from Boatoon.
Wago is the manufacturer
Date Posted: 20 January 2025 at 13:35
See here https://www.myhanse.com/connectors-for-wrth-panel_topic8849.html%20" rel="nofollow - https://www.myhanse.com/connectors-for-wrth-panel_topic8849.html
The fusion fuse is on the mainboard, not DC panel
