Mast Track Gate
Forum Name: 385/388
URL: https://www.myhanse.com/forum_posts.asp?TID=15015
Topic: Mast Track Gate
Posted By: Jonw
Subject: Mast Track Gate
Date Posted: 10 March 2025 at 06:51
Hi Helpful People
On my 385, I'm putting the sails back on, after a tidy up and clean at the sailmakers.
On my main sail, I (possibly wrongly!) removed a bolt from the mast track gate when removing the sail, in order to let the sliders 'escape' (see photo)
After putting the mainsail back on, I brought out the bolt and tried to screw it into the mast, only to find that the hole was larger than the bolt.
So - possibly I am using the incorrect bolt (seems unlikely, matches my photos, in the right place etc) or possibly there was a 'backing plate' that this bolt went into, and perhaps I was only supposed to screw the bolt in towards the mast (ie make less long) and by removing I have dropped the backing plate.
Have you any knowledge of this?
And any suggestions as to how I stop the cars from sliding down into the mast track gate?
Many thanks
Jon
Date Posted: 10 March 2025 at 09:04
On my mast there is a short length of rod that sits in the groove. The bolt that you show screws in to the rod & through it. This rod fills the entire gap in the mast track. It pushes against the back & clamps the rod in place. When one loosens the bolt the rod drops down to the gooseneck level, where it is stopped by the bolt sticking out. If one were to remove the bolt the rod would drop right down to the bottom of the mast track. Perhaps this has happened to you & the rod is just hiding from you.
Posted By: Jonw
Date Posted: 10 March 2025 at 19:14
Thank you Samuel, this might be the case..
I've had a look around in the track, and found a (slightly broken) piece of plastic, and on the bit I've found it certainly appears to be able to slide into the mast track, and perhaps the missing piece of it had the option for the screw to wedge it in place, as you mention.
I've made a temporary solution to stop the cars falling into the gate, and I'll see if I can fashion something more permanent along the lines of the piece I've found, and add something to it!
If there are any photos of the gate with the device these would of course be very welcome!
Many thanks
Jon
Posted By: AndyS
Date Posted: 10 March 2025 at 22:27
Jon:
Funny that you posted this. I just had to replace our "Z-spars flat side mainsail sail gate" as it was broken like yours. Part is Z3522. I found them at a place in France. Could not get them in the U.S. If you contact Pascal at this e-mail address (pcamenen@technique-greement.com) he will take care of you. They were about 30 euros. You are correct in that the bolt does not screw into the mast, but merely sits in there and is held in place by the piece of plastic that has a nut built in. It is not the most robust system, and a little crazy, but it is what was used.
Andy
Moonraker
River Dunes, NC
Date Posted: 11 March 2025 at 06:50
I manufactured this insert to make it possible for my (pretty large) Frederiksen cars to slide longer down on the mast.
Date Posted: 11 March 2025 at 08:24
Many thanks
Jon
Jon
You do not need any complicated shape. I am assuming that the inside of the mast groove is actually round like virtually every mast. Just cut the head off a long bolt so you have a rod that fits inside the round section inside the mast groove. It needs to be long enough so that when you put it in the void it engages with each end. But not so long that you cannot angle it into the inside of the track. It has to be slightly less than the inside diameter of the mast groove to allow you to insert it. Drill & tap it for 2 No 4mm set screws & then insert 2 socket head bolts that go through the rod & push against the back & force the rod against the front inside face of the track. The rod will stop the sliders falling down. There is no need to worry about filling the groove at the front. Being metal it will not break like plastic  will
Posted By: Brufan
Date Posted: 11 March 2025 at 10:35
On my former 32' yacht there was only a tiny hole drilled at the bottom end of mast track with a split pin put in with a piece of thin rope to grab it (and avoid losing the pin) .  This was very simple & efficient
Mahavir Split Lock Pin, Packaging Size: Bag
Bruno
hanse 355 - 57
S/Y Spicy Ginger
Date Posted: 11 March 2025 at 11:05
KISS
Posted By: Jonw
Date Posted: 11 March 2025 at 17:58
These are all really great and useful suggestions.
I'll work through and find a (simple) solution which works for me.
Many thanks
Jon
Posted By: AndyS
Date Posted: 12 March 2025 at 02:35
One more idea . . . I bought this as a back-up and it works well. $17 on Amazon. It's the
Davis Flat Large Sail Track Stop
https://www.amazon.com/Davis-Flat-Small-Track-52134/dp/B00LAHBEWU/ref=sr_1_1?crid=3NHRW5IQGIDNM&dib=eyJ2IjoiMSJ9.7bbx80RkW0WwLPWPdhW5sltxoZHmdSZsOxR4ddJ5acJoh0-B-i0URLtVGsCiwnvwd0kzIUTkg6XckdeWtHigR1TgG8daczb8uf6aHi6ajm2zWQZ8WG1xHL8ze409GS9b-xA3cRZ-ZMiOYp7hr5uNYT36exjv9cORAMPeM9DOVfWbH_8TMVmmn9EgHvRRUyp1vOs17ViDl0GgqWiFpENirl1kA1iHTFZZGOPRs3F-gSriNnh0qNjlFIIOgc7q0aLzzw7yygosQataf5W9m-2fi8aMePTvVA3bQu5wYEkgSmw.Prw7JRZYCVjkTZPBQPfs51yX-EGnj5ZPiV71aFez8DU&dib_tag=se&keywords=sail+track+stop&qid=1741746950&s=sporting-goods&sprefix=sail+track+stop%2Csporting%2C82&sr=1-1" rel="nofollow - https://www.amazon.com/Davis-Flat-Small-Track-52134/dp/B00LAHBEWU/ref=sr_1_1?crid=3NHRW5IQGIDNM&dib=eyJ2IjoiMSJ9.7bbx80RkW0WwLPWPdhW5sltxoZHmdSZsOxR4ddJ5acJoh0-B-i0URLtVGsCiwnvwd0kzIUTkg6XckdeWtHigR1TgG8daczb8uf6aHi6ajm2zWQZ8WG1xHL8ze409GS9b-xA3cRZ-ZMiOYp7hr5uNYT36exjv9cORAMPeM9DOVfWbH_8TMVmmn9EgHvRRUyp1vOs17ViDl0GgqWiFpENirl1kA1iHTFZZGOPRs3F-gSriNnh0qNjlFIIOgc7q0aLzzw7yygosQataf5W9m-2fi8aMePTvVA3bQu5wYEkgSmw.Prw7JRZYCVjkTZPBQPfs51yX-EGnj5ZPiV71aFez8DU&dib_tag=se&keywords=sail+track+stop&qid=1741746950&s=sporting-goods&sprefix=sail+track+stop%2Csporting%2C82&sr=1-1
Andy
Moonraker
River Dunes, NC
Posted By: Jonw
Date Posted: 12 March 2025 at 08:08
Thanks Andy, this makes sense, is simple, available, and aluminium, so I've ordered!
Jon
