Water maker
Forum Name: 445/455/458
URL: https://www.myhanse.com/forum_posts.asp?TID=15035
Topic: Water maker
Posted By: Wanderer
Subject: Water maker
Date Posted: 28 March 2025 at 02:35
Hello,
I have a 458 and am thinking of installing a water maker. Has anyone done so? Where did you locate it and what kind/brand did you use? Any information would be greatly appreciated.
Thank you,
Stefano Basilico SV WANDERER
Date Posted: 28 March 2025 at 03:48
Look here https://www.myhanse.com/watermaker_topic14193.html%20" rel="nofollow - https://www.myhanse.com/watermaker_topic14193.html
Posted By: Wanderer
Date Posted: 28 March 2025 at 11:44
Thank you, very helpful. I had done a search before posting but nothing came up.
Posted By: EphemeralBloom
Date Posted: 29 April 2025 at 04:12
The best choice for you will depend on your budget, desired output capacity, power availability (AC or DC), and the space you have available. You might find valuable insights and experiences shared by other Hanse owners on online forums.
Date Posted: 29 April 2025 at 13:39
There are other posts describing this. Sometimes it comes with a decision around solar as 12V power for DC watermakers can be replenished easily that way. See the posts in the forum. Many had pictures.
Posted By: Sanya455
Date Posted: 21 May 2025 at 17:58
tried Rainman potable water maker, 120-140L per hour, using AC power, cost is cheaper than ZEN 100 model.
After a bit research, just bought another patable water maker. AC 220V, 760W power, 120-140L per hour. Cost is 4450 USD including installation.
Date Posted: 21 May 2025 at 18:39
You will lose another 10% or so running AC watermaker via inverter, so those ratings plus 10% overhead make it much less efficient than ZEN100
Date Posted: 22 May 2025 at 00:02
After running a HRO watermaker for the last 11 years we have decided to replace it with a Rainman 140 AC framed unit. The HRO uses propriety items like the RO which cost US$1250 for one - 60lt/hr. The ROs for the Rainman are non propriety and can be purchased from two different manufactures of ROs - Rainman retail the ROs for US$350. The impellor for the feed pump is available from Jabsco or Johnson. The Rainman is also manual with the only auto feature being the auto flush option. Pressure setting is manual and is switching from product water overboard or to storage. Efficiency is one thing but ongoing costs, simplicity and ease of trouble shooting account for a lot particularly when you are sailing in remote areas.
Posted By: Gale Force
Date Posted: 22 May 2025 at 09:18
Hi Wayne I am interested in a water maker and was looking at a Zen,but now you have me interested in Rainman which is fully supported here in Phuket.May I ask which model you have and where have you located it.
Cheers Duncan
Date Posted: 22 May 2025 at 19:33
Duncan,
The model we have bought which is on its way to Tahiti by DHL is the 140AC Framed unit. This is the 140 lt/hr AC powered machine which draws 1250W 240v. They say it can be run off a "good" 2000W inverter or generator. Hanse mounted our old, factory option, HRO Seasafaris 400 (65lr/hr) 12V DC machine. Hanse had fitted a substantial shelf on the port side in the forepeak. The Rainman is roughly the same size frame and it will fit on the current shelf. The Rainman has 2 x 40inch membranes -the old unit had one 40 inch membrane. The two Rainman membranes can be fitted on the back of the frame, on the top of the frame or separate on the wall if you need to. The current watermaker has the CAT pump mounted under the floor in the owners cabin where the sounder transducer is mounted. The through hull for the sea water feed is there as well. I will use the same through hull because it is low in the water and I have not had any air in the feedwater problems. The two pumps for the Rainman are both mounted within the frame. We have an 240V outlet in the forepeak already and we will be able to reuse all the current pipework. There is a cheaper "modular" Rainman 140 which comes with the power unit separate from the membranes. This can be fitted into a smaller area if you don't have space for the framed version. The modular version does not come with the control panel and has these components separate which can be mounted close to the machine. There is also a smaller output "framed" version which has three shorter membranes but I think the output is only 100lt/hr. I dealt direct with the manufacturer in Sydney which had a unit in stock. I checked with the NZ dealer and he did not have the unit in stock and he would have needed to get it from Sydney plus the price was more expensive. Our Rainman should arrive in the next 7-10 days and should take a day to install.
Date Posted: 24 May 2025 at 06:50
Hi Wayne Thank you for your detailed description of your installation.It will be a big help to me when I make a decision later on this year. Most insightful Duncan
Posted By: Wanderer
Date Posted: 05 July 2025 at 13:53
Wayne,
Thank you for the detailed description. Would you be willing to post some photos of your installation?
Date Posted: 05 July 2025 at 20:53
Stefano,
We are currently halfway between Bora Bora and Samoa and am happy to post some photos of the unit fitted into our forepeak when we arrive in about 5 days time. We fitted the 140lt/hr framed unit. There is also 100lt/hr framed unit with 3 shorter ROs which could fit better for you. Rainman also supply these units with a smaller mounting frame for the pump unit and the ROs separate so the unit can be mounted in pieces into a smaller area. They also supply most of their units as a complete portable systems. Look at their website - there is a lot of information and videos on fitting, running and maintaining their unit. They supplied about 95% of the fittings I needed to fit the new machine. They also list all the systems pricing in AUD$ ex factory in Sydney, Australia. They arranged shipping it to French Polynesia at a reasonable price. They also have some distributors in various parts of the world.
Posted By: Wanderer
Date Posted: 05 July 2025 at 21:27
Wayne, Wonderful. Fair winds. I look forward to the photos,
Much appreciated, Stefano
Posted By: Issywa
Date Posted: 10 November 2025 at 17:18
Date Posted: 10 November 2025 at 21:12
Sorry for the delay in posting some images. We are still cruising and currently in the Lau group of islands in eastern Fiji. Since early June we have run the watermaker for 72.5hrs and the average TDS of the product water has been 179ppm and we have made just under 11,000 ltrs of fresh water with an average production rate of about 150 ltrs/hr. No problems since install. We normally make water for about 3 hours every 4-6 days depending on usage. If we are diving/snorkeling, rinsing dive and camera gear uses more than normal. We also have freshwater flush toilets and run an 8kg washing machine about every 3 days. There is normally just the two of us onboard. Once we stop fulltime cruising for the season (in about 10 days) I will tidy up some of the pipework and remove the old DC cabling. The unit is bolted to the platform which Hanse fitted for the original watermaker. The RW inlet if next to the sounder transducer just in front of the keel under the fwd cabin floor. There is a "plankton" filter there before the pipework runs direct to the watermaker. We had a UV treatment unit fitted for the previous watermaker which we left in place. So product water leaves the watermaker, runs through a activated charcoal filter then through the UV unit then to the water tank.
The control panel is simple and manual except for the auto flush. We flush the unit with FW for about 12 minutes after use.
Posted By: Keakaka
Date Posted: 11 November 2025 at 19:14
Have a look at this unit- it is a new design and good reports from users. Good price as well. https://aquaplumb.co.nz/watermakers/" rel="nofollow - https://aquaplumb.co.nz/watermakers/
------------- This is not a rehearsal. Go for it. Kiakaha
Date Posted: 11 November 2025 at 21:19
Sorry, those aquas are rated at 12AŚ230V=2,760 Watts. Almost like running a couple of medium sized boat air conditioners. Where will all this power be coming from?
Date Posted: 12 November 2025 at 01:50
Our Rainman 240V50hz runs at 5 amps for 160+lr/hr. Rainman say this unit can be started using as low as a 2000W inverter.
Date Posted: 12 November 2025 at 14:21
Two major decisions:
1. Power (12V or AC) 2. Contained or modular
Typically, an AC unit is capable of making more water per hour than a DC unit. The obvious drawback is you need to make or have AC power to do so. A DC unit can be powered by solar panels or batteries but typically makes less gallons per hour (say 13-15gph vs 30-40gph). DC units are (usually) quieter. As such they can almost run continuously and not be noticed. AC units are similar to running a generator in noise output and, in fact, may require the generator to run at the same time.
Contained versus modular is a space and accessibility issue. Modular units let you put the setup under bunks or in tight spaces while a contained unit puts it all in front of you in some kind of casing. From a repair or maintenance perspective, its far easier to work on a contained unit. I take the membranes from my unit home every winter for storage and its simple to do so. If I had to work in a tight space or under a berth to do so.....well....
As I had a "utility" cabin on my 575 with a washer / dryer, tool storage, etc. I put a contained unit in there. One benefit of a contained unit is that you can install a tray under it to catch any water from maintenance or problems (leaks, etc.). Mine is stainless steel and works great when I winterize the unit or change filters. My system is a "Blue Water Desalination" Express system with a rating of 38-40GPH. I could expand it by adding another membrane, but no need. Its an AC unit. Given the size of my solar array (900 watts) and the fact that I have an excess of DC Solar in the PM, I might have gone with a DC system, but hindsight is cheap. See pic:
Note the stainless tray and the fact that "its all right there". A modular unit is probably better for someone trying to find space here and there on a boat. What you see here is the space you need in a contained unit. FWIW
Date Posted: 13 November 2025 at 06:17
Hi Rick I am glad that you have shown your installation as I am about to use the same place.So I have a couple of questions for you if I may. First off I was little concerned if the shelf would be strong enough to hold the considerable weight of the unit so obviously you are very happy with that. Could you please share how you plumbed your unit in. I was thinking to take the raw water supply from the A/C raw water intake and use the washing machine outlet for the waste water I was going to use the power supply to the washing machine to power the water maker. Did you bolt the water maker to the shelf? I am a little concerned that the A/C raw water intake is not close enough to the centre of the boat and air could get in the system in a small chop! I am putting in a contained Rainman 140 lph and it looks very similar in dimensions to yours Any advice would be most welcome Cheers Duncan
Date Posted: 13 November 2025 at 09:05
Could you please share how you plumbed your unit in. Hanse did not provide an option for fresh water heads when we built the boat. As such I took the normal, manual, heads and converted them during the commissioning process. This left a raw water seacock unused aft. I re-used that to be the intake for the water maker. A strainer was added. This leads under the sole to the high pressure pump under the floor where the air conditioning manifold resides. From there it runs to the water maker. I suppose you could add one more connection to the AC manifold, but I'd be wary of running the water maker and the AC at the same time for flow rate reasons.
Note that I don't have much respect for how Hanse does seacocks so in 2020 I replaced all the seacocks and thru-hulls with solid bronze, one piece, flanged, GROCO units. On the engine, AC and watermaker I also added exterior hull strainers (we have eel grass in a lot of New England and this helps quite a bit in avoiding the HF errors when the strainer is clogged). Probably TruDesign (marlon) would be another acceptable option, but this is really unrelated to the question. Same plumbing outside of this. I was going to use the power supply to the washing machine to power the water maker.
As my watermaker is an AC unit, I put in a separate feed to the nav station AC panel AUX switch. I have a dual feed "soft startup" option as these things draw quite a bit when they start up. This soft start option should be researched if you have an AC unit as it reduces the draw quite a bit on startup. I'm not an electrician, so I had the marina do this in the proper way.
Yes. If you look at the tray you will see the bolts underneath with rubber bushings and stainless bolts. They are water sealed and also assist with any vibration. The tray was actually full one time when I accidentally lost the contents of a filter. No problems.
I
chop!
Again, our boat is a 575, and has a different hull, but we have had no problems with that. The seacock is even with the aft head, just forward of the stern thruster. I must admit that I have never operated the watermaker in a chop. Usually we are doing it at anchor or in calm waters. The thru-hull is about 4-5' off of centerline.
You didn't ask:
Our fresh water tank is under the forward master cabin berth. The line running to travels to it under the centerline sole and takes a left toward that side of the tank. Not a difficult run.
I added a carbon filter to put some taste back into the water.
I added 1" lead/foam sound insulation to the area around the high pressure pump to reduce the noise. This has the added benefit of reducing the AC pump noise by about 90%. Hanse ships the boats with zero sound insulation.
I added some Y valves coming off the unit to allow for "sampling" of the product. You want to test it coming out of the machine directly as you (probably) have things in your tank that could skew a test.
As I am operating in a cold environment, I also put a Y-valve coming off the brine discharge so I could reuse the fluid during the winterization process. Flip a lever and it effectively creates a loop so that I don't just dump it overboard but send it back into a bucket. This is also useful for membrane cleaning. Look at the ongoing maintenance needs for the unit and see what would help from a plumbing perspective.
Wayne seems to have the Rainman unit and might be able to give you brand specific input.
Good luck!
Date Posted: 13 November 2025 at 21:46
Duncan,
We often make water whilst sailing, motoring or motorsailing and haven't had any problems. The seawater intake position you are talking about should be fine to use whilst underway. On our boat the washing machine water going over board is plumbed to the aft greywater sump and I would think this would not be a good option for a watermaker because of the amount of water going through the unit and back to the sea - about 700ltrs an hour for the Rainman 140 units. I would think you would need a overboard going directly overboard - you could maybe use the sink over board (on our boat this going directly overboard).We have a dedicated above water thru hull for the return water which I think is better. You could fit a similar thru hull whilst the boat is in teh water because it is best to be above the resting water line. I think ours is about 100mm above the top hull stripe. Lastly if the two RO housings on the normal 140 unit are too long for the space you have Rainman supply a three RO unit with shorter ROs compared to the two RO version. The mounting plate for the ROs (seen as the blue RO frame in my photos can be mounted on top of the unit - like we have, or on the back of the unit or remotely if this makes your install easier.
