Water pump
Forum Name: 345/348
URL: https://www.myhanse.com/forum_posts.asp?TID=15073
Topic: Water pump
Posted By: Sounder
Subject: Water pump
Date Posted: 26 April 2025 at 15:30
Loud vibration when running water through faucets and shower. Fresh water tank is full. Any idea what’s wrong or how I can fix this?
David S
NADINE (Hanse 348 #199)
Western Long Island Sound
Posted By: Sounder
Date Posted: 10 June 2025 at 14:05
Does anyone know how to prime the water pump? I still seem to have air in the system causing a vibrating sound when the water pump faucets or shower are on. I don't think that is normal.
Also, any recommendations on how to clean silt out of the fresh water tank?
David S
Date Posted: 10 June 2025 at 17:22
The pumps are reciprocating pumps so they are noisy.
If you have to replace the pump, then put a pump guard filter between the tank and the pump
https://www.force4.co.uk/item/Jabsco/Pump-Guard-For-Fresh-Water-1-2-Hose-Fine-Stainless-Steel/G4D" rel="nofollow - https://www.force4.co.uk/item/Jabsco/Pump-Guard-For-Fresh-Water-1-2-Hose-Fine-Stainless-Steel/G4D
We occasionally use a small 12v submersible pump to "hoover" up any sediment in the water tank.
https://www.marinesuppliesdirect.co.uk/whale-standard-12v-submersible-pump-gp1002-4608-p.asp" rel="nofollow - https://www.marinesuppliesdirect.co.uk/ - whale-standard-12v-submersible-pump-gp1002-4608-p.asp
I tape it onto a thin old sail batten and you can clean up any residue.  It could also act as a spare emergency water pump.
https://www.amazon.co.uk/Whale-GP1002-Standard-Submersible-Pump-White/dp/B004E1T67E/ref=asc_df_B004E1T67E/?tag=googshopuk-21&linkCode=df0&hvadid=309952946065&hvpos=&hvnetw=g&hvrand=673318980664246594&hvpone=&hvptwo=&hvqmt=&hvdev=c&hvdvcmdl=&hvlocint=&hvlocphy=9041112&hvtargid=pla-404190844506&psc=1" rel="nofollow - https://www.amazon.co.uk/ - Whale-GP1002-Standard-Submersible-Pump-White/dp/B004E1T67E/ref=asc_df_B004E1T67E/?tag=googshopuk-21&linkCode=df0&hvadid=309952946065&hvpos=&hvnetw=g&hvrand=673318980664246594&hvpone=&hvptwo=&hvqmt=&hvdev=c&hvdvcmdl=&hvlocint=&hvlocphy=9041112&hvtargid=pla-404190844506&psc=1
