301 fridge
Forum Name: 300 / 301
URL: https://www.myhanse.com/forum_posts.asp?TID=15077
Topic: 301 fridge
Posted By: PabloPicasso
Subject: 301 fridge
Date Posted: 28 April 2025 at 18:28
Anyine converted the 301's coolbox to a fridge?
Posted By: perry
Date Posted: 29 April 2025 at 07:11
Yes I did. realatively straight forward.
But make sure you add as much insulation as you can fit in. The efficiency [power consuption] depends on improving insulation, and the controller. I have since changed from H301 to my H 315. On the 315 when the controller failed I fitted an electronic digital controller and it trtansformed the fridge efficiency. The standard Isoptherm / Dometic controllers are rubbish, and varstley over priced.
Cheap from china but it works well can be bought from number of sites get it from UK stockist but this is example on Amazon, not where I got mine:-  https://www.amazon.co.uk/All-Purpose-Digital-Temperature-Controller-Thermostat/dp/B07J1JWNR7?source=ps-sl-shoppingads-lpcontext&ref_=fplfs&psc=1&smid=A2LZADUCQG7RBO&gQT=1" rel="nofollow - https://www.amazon.co.uk/All-Purpose-Digital-Temperature-Controller-Thermostat/dp/B07J1JWNR7?source=ps-sl-shoppingads-lpcontext&ref_=fplfs&psc=1&smid=A2LZADUCQG7RBO&gQT=1
Current Yacht Hanse 315 2007
Date Posted: 29 April 2025 at 16:00
Thanks for that answer.
Where did you fit the compressor?
Posted By: perry
Date Posted: 30 April 2025 at 07:54
Both Isotherm and Dometic make kits to fit to boat. This consists of a compressor and cooling plate, controller. the compressor and cooler plate are pre-filled with refridgerant, so on final assembly you join the tubes and no need for refrigerant engineer to fill with refridgerant.
Currently in UK chandler "Force 4" they are listed at Dometic £749 and Isotherm at £425
You should find installation notes on their websites.
Must go we are loading final bits of food on boat.
Perry
Date Posted: 02 May 2025 at 08:14
Thank you for those replies. All very helpful
