Steering cable replacement
Forum Name: 385/388
URL: https://www.myhanse.com/forum_posts.asp?TID=15080
Topic: Steering cable replacement
Posted By: Mark&Catherine
Subject: Steering cable replacement
Date Posted: 29 April 2025 at 20:41
Ok so last season we had the dreaded failure of our steering whilst trying to go stern to on the town quay on Amorgos in Greece. No problem for an old dinghy sailor, get the boat back under control with the autohelm and fish out the emergency tiller, circle round and moor up without too much stress.
However, try and get spares or something fabricated on a remote island. No chance. First learning point, why don't I carry spare steering cables. Yes they are a bit pricey, but the chances of finding them when you need it if you are anywhere remote is close to nill.
So we sailed from Amorgos to Leros (our home marina) using the tiller and autohelm. We then ordered a complete set of cables from the local chandlers, and whilst we cannot fault the service it was about 10 days before the new parts arrived, we ordered a specific set for our 385, and jeffa made them to order, rather than the generic set that would have fitted but were not as easy to fit.
Ok so on to this year, the boat was launched 3 days ago and we had the new parts. We spent a couple of hours trying to work out how to get the cables replaced without removing the pedestals, but failed.
At this point I rang back to Inspiration marine, our hanse dealer that we had bought the boat from in 2013.  They, as usual, were brilliant. I mean it's 12 years since we bought the boat, but they were there for us and explained that we had to get the part of the cockpit floor on which the pedestals are mounted up and go from there.  Having dug out the seven teak plugs covering the bolts holding the cockpit floor together, it was quite easy for a couple of engineers (me and a mate) to figure out how to get the old cables out and the new ones in. It took us about three hours for the whole thing.
On inspection, the one cable failed at the point where it rounds the sheave  at the base of the pedestal. All the other cables showed rusting in the same location.
So my recommendations. Buy a spare steering cable set now before you need it, unless you are infrequent sailor close to a jeffa agent.  Spend some time to grease the cables as they turn at the base of the pedestals from time to time, yes I know it's on the jeffa list of annual maintenance, but make sure you do it, we didn't have that list until I found it on line.
To be fair, our cable failed at 12 years and we sail a lot. In future I will change them every 7 or 8 years, perhaps when I change the sail drive gator. I will always have a spare set on board. And learn to use your emergency tiller, no problem for me, but maybe not for everyone.
And finally if anyone needs to know exactly how to change your cables, let me know and I can talk you through the process. It's tedious but if you have a practical mind not too bad, only 3 hours and the entire set is now brand new.
Posted By: spam
Date Posted: 29 April 2025 at 23:02
Good point about having a spare cable.  Do you have a part number by any chance?  Where did you buy it?  How much was it?
Harold
S/V Ventus
H415/314
Date Posted: 30 April 2025 at 14:35
You can order them directly from Jefa using this email.
ls@jefa.com
But we used a local chandlery to order them, you can order each part or a complete set, prices for the whole set (both wheels) was Euro 506 plus VAT.
Posted By: spam
Date Posted: 30 April 2025 at 16:10
very helpful, I might order a spare set
Posted By: Rhum coco
Date Posted: 03 May 2025 at 19:05
Bonjour Mark et Catherine
Quand vous retirez les vis qui sont dans le teck,est ce l'ensemble des 2 socles des barres à roue avec le support teck qui s'enlève  Je voudrais demonter ces 2 socles pour refaire la peinture.merci
Date Posted: 04 May 2025 at 09:36
Yes once the 7 screws are removed and you loosen the steering cables you can tip the whole assembly forward. If you want to you can then unbolt the wheel stands and remove them for painting.
Oui, une fois les sept vis retirées et les câbles de direction desserrés, vous pouvez basculer l'ensemble vers l'avant. Si vous le souhaitez, vous pouvez ensuite dévisser les supports de roue et les retirer pour les peindre.
Date Posted: 04 May 2025 at 09:41
Merci beaucoup
Posted By: Ken Haas
Date Posted: 24 July 2025 at 15:56
@ https://www.myhanse.com/member_profile.asp?PF=3972" rel="nofollow - Mark&Catherine
Thank you for this thread.  I am curious if you have any photos of the installation?
Thank you.
Ken
Posted By: Ian Coverdale
Date Posted: 24 July 2025 at 22:33
Jefa steering cables required annual inspection and cable greasing. There is a very easy to understand maintenance guide on Jefa website.
https://bsidk.com/app/uploads/sites/12/2022/03/Annual_wire_system_check.pdf" rel="nofollow - https://bsidk.com/app/uploads/sites/12/2022/03/Annual_wire_system_check.pdf
At my first inspection on buying six-year old boat, looked like no grease had been applied ever ... grease give important corrosion resistance.
Cheers.
Ian & Andrea
SV Gabrielle (H445)
Posted By: lide
Date Posted: 22 January 2026 at 03:12
Here's another piece to keep around.
The chain linking the 2 ends of the cable broke. Boat was under autohelm and the sea state was less than 1 meter waves. Fortunately I was aware that the steering quadrant remains under control while connected to the autohelm. Fetched the emergency tiller and got back into port.
The chain looks pretty chunky and is inscribed with 50SS on mine. I will be replacing it with some motorcycle chain that's easily available. By the looks of it it's never been greased so probably some corrosion has weakened it. In any case boat has just crossed 10 years so I imagine it will start showing some issues like this.
Posted By: sgjohnston
Date Posted: 22 January 2026 at 09:38
Any hints on how to inspect the sheaves, without removing the pedestals? We tried last year, and they are very inaccessible. Might try again with an endoscope, but if there are better ways I would love to hear about it!
Hanse 345 Gigha, based in Largs
Date Posted: 22 January 2026 at 12:58
You can do it with endoscope but to grease you will need to remove the steering wheels. Jefa has precise instructions on their website. Read here as well:   https://www.myhanse.com/steering-chain-failure_topic14094.html" rel="nofollow - https://www.myhanse.com/steering-chain-failure_topic14094.html
