Sentinel not recognizing shore power
Forum Name: 445/455/458
URL: https://www.myhanse.com/forum_posts.asp?TID=15108
Topic: Sentinel not recognizing shore power
Posted By: Resilient
Subject: Sentinel not recognizing shore power
Date Posted: 13 May 2025 at 17:18
My Sentinel App is suddenly not recognizing my shore power connection.  I saw where others has this same issue, but not where they addressed its.  Any ideas?  Where is the unit located on a 458?
Chip
Chip
Hanse 458
Resilient
Hull 238
Date Posted: 13 May 2025 at 18:53
The unit is behind VHF, but cannot comment why it is failing, you can likely email Sentinel, they have been responsive. The wiring to Sentinel is pretty simple to track, wires in the battery compartment are clearly marked.
Posted By: 32mike
Date Posted: 14 May 2025 at 02:09
Mine does the same. I think it was related to a lightning strike at the marina a few slips down but I can’t confirm that. I haven’t tried to troubleshoot it. I did call Sentinel but they didn’t have any good suggestions. I’ve just accepted it. Everything else still works.
S/V Dulces Sueños
458 #087
Tampa, FL
Posted By: Nebulas
Date Posted: 30 October 2025 at 10:11
There is a little step down transformer between your shorepower and sentinel unit. Could be the culprit especially after lightning
Posted By: 32mike
Date Posted: 30 October 2025 at 10:19
Do you know where that little transformer sits? I haven’t come across it yet.
S/V Dulces Sueños
458 #087
Tampa, FL
