electric main heads
Forum Name: 460
URL: https://www.myhanse.com/forum_posts.asp?TID=15131
Topic: electric main heads
Posted By: ariette
Subject: electric main heads
Date Posted: 24 May 2025 at 15:30
The electric head (port main) has started to backfill so needs the joker valve cleaning or replacing I guess. The problem is I can't find it. Part from glued in panels that I am reluctant to tear out there is no obvious location unless (quite possibly ) I am being very stupid. Any help gratefully accepted - including alternatives to cure the backfilling problem
Posted By: voiceman1uk
Date Posted: 26 May 2025 at 19:13
If it is the same as mine you will have to take the head out…two screws one each side on and lift the head out …you will find the macerator etc on the back of the head, not the easiest things I have ever worked on
Posted By: angorsan
Date Posted: 27 May 2025 at 10:06
If that is one from Jabsco - you can find a diagram with all the part on the internet - just need to know the exact model, e.g., here is one for E2:
https://manuals.plus/jabsco/quiet-flush-e2-electric-marine-toilet-manual" rel="nofollow - JABSCO Quiet Flush E2 Electric Marine Toilet User Manual
I have it fitted aftermarket, so don't know which one comes from factory :(
