Which Battery Bank Does The Windlass Run Off?
Forum Name: 445/455/458
URL: https://www.myhanse.com/forum_posts.asp?TID=15153
Topic: Which Battery Bank Does The Windlass Run Off?
Posted By: mattplowman
Subject: Which Battery Bank Does The Windlass Run Off?
Date Posted: 31 May 2025 at 04:55
I have a 2014 445 and I am installing a deck wash down pump , I am going to wire it to the closest battery bank which is the bow thruster battery under the bed. I am trying to figure out if the windlass also runs off the thruster battery? We are likely to never be using the thruster and deck wash down pump at same time but windlass and pump will be used simultaneously so wanting to figure out max draw I need to account for on the battery.
I have 3 banks , starter , house and thruster.
H445 #210
Date Posted: 31 May 2025 at 05:06
I think you are talking about WindlAss, in which case it should run from the house bank and draw something in the range of 100Amps, the pump you will be installing should draw 10 times less...well unless its a power washer.
Date Posted: 31 May 2025 at 08:27
Windlass is definitely on the house bank.  I find this strange given the longer cable runs.  I'm aware that the bow thruster is an option but I'd have thought that there would have been advantages in combining this option with alternative power supply for the windlass.
However I'm not 100% that the thruster battery is 12V  It might be 24V so I'd check this before connecting more to it.
Date Posted: 31 May 2025 at 09:31
I think because thrusters take a lot of power (4kW or more) , those dedicated batteries get quickly depleted even if you would have standard 12V system. Something that you dont want your windlass to hook up to. And its true many thruster battery banks are wired for 24V to handle high current draws. I just faced this dilemma while installing bow and stern thrusters on my boat and went for 6.5kW 24V thruster motors and dedicated 24V battery banks with calculated capacities allowing thruster runs for only about 15min or so. As a result, I dont see any further use of those added battery banks.
Date Posted: 31 May 2025 at 23:02
Thanks all, very helpful. My thruster battery is 12v , will hook the wash down pump to that today…..one less job on the job list!
H445 #210
Posted By: 32mike
Date Posted: 01 June 2025 at 13:36
Just curious - how are you routing the wire from the bow thruster battery to the deck for the wash down pump?
S/V Dulces Sueños
458 #087
Tampa, FL
Date Posted: 03 June 2025 at 22:25
Hi Mike , my forward storage locker has a metal panel already installed through the bulkhead into the forward berth (thruster battery under the bed). This panel has water pipes connected from the main water tank under bed into the storage area and then up to the intake in the deck and into the overflow outlet. It also has a smaller connection pipe that has a wire run already (the forward storage area has a light , chain counter and 12v socket that are wired to the thruster battery as well). This has been made "watertight" by filling with sealant after the wires were run (before my ownership). The hardest part of the job has been getting that sealant out!
H445 #210
Posted By: 32mike
Date Posted: 04 June 2025 at 00:30
I’m guessing it looked like this before the wires were run. So, I was thinking that, for a wash down pump, I would use that plugged pass through for tubing for sea water intake for the pump. I would run the tube on the inside down into the floor and tee off the seawater intake for the toilet flushing. Doing that, I would still need to run power from somewhere. The windlass and nav light wires are run from the port side right up under the deck. Where are you drawing the seawater for the pump?
Any body else with a 455/458 have a Hanse installed wash down that can show me how they wired/plumbed it from the factory or how you did it yourself?
S/V Dulces Sueños
458 #087
Tampa, FL
Date Posted: 04 June 2025 at 00:39
That's it exactly.
On my 445 a previous owner had installed a tru design intake/ball valve in the hull below that panel. It was never used so I have just plumbed the deck washdown pump to it (I am 50/50 as to using the same one for a water maker as I am told there are issues with airlocks when underway but that is TBC)
H445 #210
Date Posted: 04 June 2025 at 01:36
I didnt install the pump but I run a few wires (12V aux power and communcation cable for windlass control from the cockpit) from nav station up inside the port channel along with windlass cables all the way to the front locker. The only narrow place is to pass thru the head but doable. There is black protecting cover that hides windlass cables in the locker, make a small cut, pass the fishing wire, get another end in the cabin, and so on
Posted By: 32mike
Date Posted: 04 June 2025 at 02:17
Thanks Marsella and Matt. Good food for thought. I don’t think I want to drill any more holes in the hull - there’s already a bunch. The wiring sounds typically tricky. Without having tried it yet, I would have figured the fishing tape wouldn’t get through. Something for later to try.
S/V Dulces Sueños
458 #087
Tampa, FL
