Erratic depth readings
Forum Name: 400
URL: https://www.myhanse.com/forum_posts.asp?TID=15167
Topic: Erratic depth readings
Posted By: Ratbasher
Subject: Erratic depth readings
Date Posted: 04 June 2025 at 08:41
This post briefs on the symptoms, likely causes and fix of a potentially hazardous issue on an original-fit Raymarine depth-sounder.  As I know for certain that one other person has experienced similar issues I'm detailing it as part of the forum's archives.
Earlier this week I aborted a trip to the Isles of Scilly, where there's often a need to take 'overground' passages which are only passable at high tide.   The wind had been fair with everything working well but I needed to motorsail to make a tidal gate in good time.  Soon after starting the engine, the depth sounder started reading from 2 to 65m and every depth in between. Charted depth was 65m and I'm sure there was nothing fouling the sensor: no bubbles, weed or submarines below. The integral speed log worked properly throughout.  This had happened twice before in previous years, both times again in the region of the Manacles rocks but the issue had ceased immediately on isolating the bowthruster and windlass.  While this indicated that the cause was interference with the HT cables which shared some of the route it didn't explain the long periods of full functionality in between in waters far away from the Manacles.  However, this time the issue remained despite our best efforts; the gauge worked fine with the engine shut down but never with it running; we tried several times.  Although we've actually got a lead-line I wasn't willing to trust the boat to our skills with it around the Scillies so we diverted and enjoyed a fast sail to Plymouth with everything reading properly.  To our surprise, starting the engine to enter a lock the wretched sounder behaved perfectly, mocking our earlier efforts.
Starting to wonder if there was some sort of electronic 'Bermuda Triangle' around the Manacles, on later tracking the route of the transducer cable I found that no less than about 5m of cable had simply been stuffed behind the inaccessible forecabin locker where it was loose to jumble about in close proximity to all other cables, including the leads to the windlass and bowthruster.  The end was wired into a grey box under the fuse panel where it terminated in a number of spade fittings, instead of the more modern Raymarine STNG fittings with which all but the (2008-vintage) Airmar transducer had been replaced in the past 3-4 years.  This presented a number of potential causes for the random symptoms experienced:  poor connectivity, excess cable length, electronic interference and corrosion being but a few.
I got a new transducer with an appropriately-sized cable which plugged straight into the STNG system and - so far - all looks good.  The acid test, however, will come on returning to the Manacles where, quite possibly, 'there be (electronic) dragons'......
I can only conclude that the excess cable had been present from build and was lazily installed, something which seems even with brand new boats to be a not-uncommon failing.  Anyone experiencing similar symptoms - or anyone just curious - may care to identify the transducer cable where it passes under the port-side chainplates and give it tug.
Posted By: DJgun
Date Posted: 04 June 2025 at 14:18
I experienced erratic readings from Raymarine i50 Tridata and  depth sensor a number of times. In approx 16m of water the shallow water alarm would go off and depth show as 2.5m (from surface). All times while sailing.
I thought maybe I'd just sailed over a Bull shark or something.
But it was so annoying I fitted a DST810 Airmar Triducer at next haulout, which is NMEA 2000 thus taking the i50 Tridata out of the loop. Unfortunately it only ran for about 1.5 hours before failing, which then needed weeks before a replacement was provided.
The original transducer is still in situ, so I can connect it if the Triducer fails again, which us apparently common.
DJ.....Sailor Ordinaire
HIN DE-HANJ0331J708
Posted By: Mark_J1
Date Posted: 05 June 2025 at 07:19
Iain - yes I’ve had similar erratic behaviour with the original ’analogue’ transducers. In the early phase of the fault, it consistently responded to better earthing of the wire shield connection on the log sensor but then reoccurred for no good reason.  It was almost like a static charge buildup which I had to discharge to earth!
After a couple of seasons of the fault frequency increasing, I got fed up and did the awkward wardrobe tilt job to pass the needed NMEA2000 cable and swapped to an Airmar DST810 triducer with Bluetooth etc on Stbd. That’s worked fine. I left the analogue depth transducer in place on Port as my issue seemed to stem from the Log side of things and have had consistently good results from it ever since. Even though it is still using the original cables!
I’ll keep my fingers crossed the DST810 survives.  As the 810 is a 235Khz transducer (original is 150Khz I think) I can run both transducers simultaneously so it’s also given me a redundant depth transducer solution for my troubles :)
