Lewmar Hatch methacrylate panel replacement
Forum Name: 370 / 375
URL: https://www.myhanse.com/forum_posts.asp?TID=15169
Topic: Lewmar Hatch methacrylate panel replacement
Posted By: LuisLey
Subject: Lewmar Hatch methacrylate panel replacement
Date Posted: 04 June 2025 at 17:59
My boat is a Hanse 370E built in April 2007.
We found a leakage in the saloon hatch cover - Lewmar Low Profile Hatch Size 60 - and realized that the lack of watertightness is because the methacrylate panel is heavily bent around the friction lever.
Any recommendation on whether to fit a new panel or renew the whole cover? Alternative solutions are also welcome.
Date Posted: 05 June 2025 at 16:05
Could you post some pictures? Can't understand how the glass could bend.
My 370 also had a main saloon hatch leak, but it was the screw holes for the aluminium fittings for the window frame that was the issue.
Hanse 370#487 30HP 3-cabin
Posted By: LuisLey
Date Posted: 05 June 2025 at 16:35
uploads/8743/Hatch_cover.pdf" rel="nofollow - uploads/8743/Hatch_cover.pdf uploads/8743/Panel_detail_iwo_Friction_Lever.pdf" rel="nofollow - uploads/8743/Panel_detail_iwo_Friction_Lever.pdf
Posted By: Ggerrit
Date Posted: 06 June 2025 at 07:04
I had also a leakage, but replacing the seal between the acryl and the pvc lock solved it.
no more than 10,-...
H400 2008 2 cabin
Date Posted: 06 June 2025 at 09:39
The tension/strength of the gray plastic bracket can be adjusted. Looks like new sealant between the frame and glass as already suggested is the right path.
Posted By: MasterKeil
Date Posted: 06 June 2025 at 11:43
I replaced the Lewmar this winter. Cost including installation 1000 €.
Hanse 370#640 "Nemesis"
