Yanmar starting without power switch
Category: General
Forum Name: Chit Chat
URL: https://www.myhanse.com/forum_posts.asp?TID=15172
Topic: Yanmar starting without power switch
Posted By: MasterKeil
Subject: Yanmar starting without power switch
Date Posted: 07 June 2025 at 19:26
Are there any disadvantages besides the not working warnings and engine blower when I start the engine by using the start switch and not the power switch? I had an failure to push the power switch in and started the engine by using just the start switch.
Hanse 370#640 "Nemesis"
Posted By: Mark_J1
Date Posted: 07 June 2025 at 22:56
If I understand correctly what you’ve done, you’ll potentially find the engine starts and runs, however the alternator may not get the right signals. So you may have no charging.
Posted By: martijnvdh
Date Posted: 09 June 2025 at 14:49
On our 2005-built 371 I need power to the system also to be able to shut the engine down with the stop button. Without power, I need to press the stop-solenoid on the engine manually.
