Low AC voltage
Forum Name: 575/588
URL: https://www.myhanse.com/forum_posts.asp?TID=15179
Topic: Low AC voltage
Subject: Low AC voltage
Date Posted: 10 June 2025 at 12:17
Has anyone experienced low AC voltage when trying to run appliances off the inverter or generator. In USA boats, the 230 volt inverter voltage is stepped down to 115. In practice it measured closer to 113. Problem is that with voltage drop over the wiring, any 1000 to 1300 watt appliances will only see about 105 volts. Some will tolerate this and others will struggle. Specifically my microwave doesn’t power as it should and some coffee machines don’t work at all.
Posted By: Sounder
Date Posted: 10 June 2025 at 12:40
I have definitely noticed the same. No idea how to improve that. When I've asked at McMichael they tell me the boat needs to be hooked up to shore power for appliances, coffee maker, etc.
David S
NADINE (Hanse 348 #199)
Western Long Island Sound
Posted By: 32mike
Date Posted: 10 June 2025 at 14:04
Yeah, I’ve had the microwave not work properly off of the inverter from the battery. I’ve tucked an away inside my brain that I need to run the generator or be on shore power for the microwave (or upgrade to a better lithium setup.)
S/V Dulces Sueños
458 #087
Tampa, FL
Posted By: Sounder
Date Posted: 10 June 2025 at 14:07
Would running the diesel allow these appliances to run? I don't have a generator.
David S
Date Posted: 10 June 2025 at 14:56
Not sure I understood the setup with 240V needed to step down to 120V. Shouldnt it be just 12V DC to 120V AC inverter installed? For
1200W/120V appliance, the current is only 10A, any reasonably sized wire (12AWG or something) should carry it without any voltage drop, otherwise same problem would exist inside every house in US.
Date Posted: 10 June 2025 at 16:11
I've seen it, but only in combination based upon the amp draw.    For example, if a coffee maker is taking 20amps and an icemaker is taking 15 amps, then you have likely maxed out the 32amps the 110 step-down seems able to provide.   Even worse, there are two legs which (I believe) have 16amp maximums (for the 32) coming off the step-down.  Max out the 16 and you have the issue even if you are far below 32.
I replaced the Mastervolt inverter/charger that came with the boat, but the capabilities of any replacement unit are constrained by the above 110V setup.
FWIW
Date Posted: 10 June 2025 at 19:46
To answer Marsella, the inverter makes 230 volt from the batteries. From there it is stepped down to 115 by a separate transformer. And Rick, the Victron unit puts out one leg at 32 amps, not two at 16. The problem we are having is not because the units are being overloaded. It is because they are proving a low voltage to start with and a bit of wiring voltage drop to the appliance. BTW this occurs regardless of how many appliances are running. I’m working on a solution to bump the 115 up to a more usable 125.Ans Sounder, running the engine won’t help because the inverter already makes adjustments for DC voltage drop in order to provide a steady AC voltage.
Date Posted: 10 June 2025 at 19:58
You are correct.   Its 32amp.    I was told it was 16amp by the post-sales tech guy from my dealer, but I just checked in the manual and its definitely 32.
Date Posted: 10 June 2025 at 20:45
Ok I understood about transformerThumbs Up In my setup, I have two separate inverters, one, 12V to 120V, that powers wall outlets and waterheater, and separate one, 12V to 240V that powers air conditioners. Never had a problem with 120V, (max tried 2kW for espresso machine and heat gun), but had a problem with 12- 240V inverter, where my 1.5kW saloon ac unit would stop after working 10 min or so with the error code "underpower' or something like that. My other two ac units take about 1kW and work without a problem if run separately. I was puzzled what would be the reason why the inverter rated at 3kW cannot handle more than 1 kW but eventually discovered the problem with one of 12V battery cables going to the inverter was loosely connected, and after I tightened the bolt, the problem disappeared.
Date Posted: 10 June 2025 at 23:01
We have 2 x 12V/3000W/120A-50 Victron inverter chargers running together. I have used the Victron VE Configure 3 software to make changes to the system including setting both to run together or to run just one. One of the settings is AC voltage output. Ours are 240AC 50 HZ units and the default voltage setting is 230, min value 210V, max value 245V and can be set in 1V increments. I have set ours as 240V. We run our coffee maker, TV, vacuum, washing machine, water heater and our new AC powered watermaker all off the inverter/chargers and often multiple items at the same time. You can also set the charger from 120amps downwards. I have set ours at 100 amps each (ie 200amps total) at our electricians suggestion who thought running the chargers for long periods to charge the lithiums at the max output may shorten their life. To run the VE Congif software (downloadable from Victron) you need a Interface dongle MK3 to USB.
Date Posted: 11 June 2025 at 00:38
Right point about setting up max output voltage for the inverter Thumbs Up Mastervolts can do 230/240V and 50/60Hz via dip switches, no software needed
Posted By: 32mike
Date Posted: 11 June 2025 at 01:03
My MasterVolt Mass Combi can only change the frequency to 50 or 60hz but there’s only one voltage out of 230v +/- 5%.
S/V Dulces Sueños
458 #087
Tampa, FL
Date Posted: 11 June 2025 at 01:31
Same here. My Mastervolt 2200/100 can only be run at 230.  250 would be better but I don’t know of any software patch that is available.
