Dear all ,
after the pan pan event triggered by the failure of the wurth panel, some cold blood reflections and my solution.
the first consideration, is about what's critical and non critical in a boat. I had put quite some thought while waiting for the repair parts, and concluded that everything that puts a crew in distress is critical. Because crews have very different experience (think about a charter boat , or a crew where the captain/owner is incapacitated) everything that puts at risk a low-to-medium training crew should be considered critical.
The next consideration is the following: like in life , most critical situations are created by two (or more) events happening. that's an important principle in aviation , where single failures should not compromise the safety of a flight.
the Wurth panel: its design is extremely complex, targeting convenience for non expert crews in normal conditions. Not only one processor controls it, but even the buttons pad constitutes another single point of failure. it has an (unused) nmea interface, complexity that is not used. The logic inside the wurth: one button controls via relays multiple circuits, with individual fuses. One individual relay breaking down , or an individual fuse breaking down , would also stop the circuits that are controlled by the same button. For example, a failure of the forward nmea2000 network (controlling the sonar and the windvane for example, so not critical) would put off service the autopilot.
Is the autopilot a critical device? not taken by itself: but when you have another failure (in my case , the manual steering) then it becomes critical in order to save the boat and, maybe, the crew itself (in our case , the Italian coastguard came to rescue the people but not the boat).
There are other single point of failure beyond the wurth: for example , we have a single rudder, and a large number of seacocks (I have a polyurethane plug attached to each seacock).
but my conclusion is that the wurth is an UNNECESSARY single point of failure.
Luckily I had developed a knowledge of the system that goes beyond the provided manuals: without that extra piece of information - exchanged here - it's very difficult just to localise a broken relay, or a broken fuse , or recable the necessary elements to restore the autopilot in FU mode.
and not only critical with respect to the autopilot: one critical concern of the coastguard was the absence of navigation lights at night. they correctly considered this a danger to navigation , especially approaching the harbour , that in their respect implied we had to be escorted. And there is no standard backup solution for the lights...we tried with the dinghy navigation lights...
Where you have a backup: anchor windlass that can be released manually (for those who knows how to do it), and stern door manual pump (required for those willing to use an emergency steering to release the dinghy).
Also, no water on board: my solution on a longer trip would have been either cabling the pump to the batteries, or use the boiler water lower tube , hopefully aspirating the water from the tank. very difficult to extract water from the tank in the bow cabin otherwise!
one comment on the root cause of the failure: 1 liter of water entering from the side hatch above the wurth cabinet that has a grid just above the wurth.
this is simply a bad design/mistake: I temporarily blocked the opening of the hatch, and I will implement a 3d printed conduct allowing the air to go through, but not water to splash the electronics inside ...
so my solution: I removed the damaged wurth, cut the door to host two bep marine panels (901h and 904mn). these panels offer 24 magnetothermic (MT) mechanical switches , precabled.
in this design , all the negative wires are collected onto bars - that are far away from the panel itself. the panels therefore have only 12V positives, any short circuit won't have any dramatic effect.
then , the MT switches: they are actuated mechanically , and they don't blow (requiring you to have a bag of fuses...).
this design is obviously more fail safe , and the failure of one channel is easier to repair /correct by simply using another MT, or moving the wire somewhere else. no special knowledge needed , the problem is always localized where it happens.
as you can see in the picture below , I decided not to pool different blocks and keep their control separate: for example , I can keep on the forward nmea2000 network when I am in the harbour (to record winds), and separate circuits for freezer and fridge for example.
i will put in the future thrusters here, and my second tricolor light (it was required by the ARC rules...but the independent lights were controlled by the wurth ...).
it's retroilluminated, and there is double feedback about the state of the MT (physical position and actual power at its output).
The cost was the panels (about 1.2keur, including the MT) and about a day of cabling work...
for your information , I already had tanks monitoring and voltage monitoring on a different czone system: this is also a single point of failure , but I only use it for monitoring (not control) and for non-critical components...btw: it kept working despite the water ingress , because the display and its connectors are well protected from water ingress , differently from the wurth that's completely open and with short distance positive and negative power tracks.
As many things in life: I wish I would have done this earlier, before having had the problem....we keep learning , that's why I share these considerations.
------------- Hanse588#55
