Sorry to take so long to get back with details - now in Fiji. We have a telescopic carbon pole which goes from about 4meters-6.5 meters Currently we have is set at 5.65 meters ( Mast to tip of pole) which we find works well with our self tacking headsail. We have a topping lift, a forward guy and a aft guy, the sheet runs back to a gennecker block and onto a gennecker winch. We set the forward guy and aft guy to a point forward of the beam before unfurling the headsail. A new sheath box was fitted into the mast below the standard self tacker sheath box. The uphaul goes down to a stainless steel eye about 3 meters below the new sheath box. If you want to use the normal sheeting for the self tacker you can either take the pole off the mast or store the pole on the mast ( needs to be on the side of the mast otherwise it interferes with teh normal self tacker sheet) or you can leave the pole out and set aft of the self tacker sheet so it does not interfere with that sheet. You need to make sure the pole is high enough that it can not drag in the water if it is on the downwind side. Just let out the guys and use the uphaul to set it 3 or 4 meters above the water. I attached the aft guy to the midships cleat. The fore guys goes through a fixed pad eye on the forward rail and then to the forward cleat. To gybe the pole you need to furl the sail and change sheets and transfer the guys to the other side then gybe and then unfurl the sail. Coming from Samoa to Fiji we were getting about 6.0-6.4 kn of boat speed running at about 16kn of wind at about 160TWA with just the standard 63sq meters self tacker headsail poled out. We got better speed with a wing on wing configuration with 2 reefs in the main and the headsail poled out on the upwind side. We are looking at a downwind sail of about 100sq meters which we can pole out in winds up to 20kn which will give us better downwind speed.
