Stern thruster reversed
Forum Name: 575/588
URL: https://www.myhanse.com/forum_posts.asp?TID=15237
Topic: Stern thruster reversed
Posted By: Gale Force
Subject: Stern thruster reversed
Date Posted: 04 July 2025 at 02:53
For what ever reason my stern thruster pushes to port when the control lever is pushed to starboard.What wires need to be flipped around to get the boat to move in the direction that the control lever is pushed as per my bow thruster
Best regards
Duncan
Date Posted: 04 July 2025 at 03:46
Duncan, you need to reverse the control wires located on the power relay on the side of the motor. They are black and have a spade lug on the ends. You will need to remove the orange plastic cover to gain access. Simply reverse the connections. They are designated as number 5 and 6 from the grey control box but I don’t think they’re labeled. Was there work done on the motor ?
Date Posted: 04 July 2025 at 07:57
Hiv Arcadia
Please see pic of yellow and red lugs both with black wires.I suppose I am missing the orange box top and Yes a technician has been mucking around down there.
So are the red and yellow lugs the ones to be swapped.
Sounds like a bomb disposal situation!!!
Cheers Duncan
Date Posted: 04 July 2025 at 14:13
 No. The yellow lug with the double black wires stays put. There should be a red lug with a single black wire on the opposite side of the relay. There will also be a yellow one there as well. Use the two red ones.  Be sure to use the exact same terminals on the relay when you swap.
Date Posted: 05 July 2025 at 03:33
Hi Arcadia
Many thanks for that simple fix.Everything now goes in the right direction and have marked the wires for technicians in the future
Much appreciated
Duncan
Date Posted: 05 July 2025 at 03:52
Don’t you wish all fixes were that simple!! Boy, you’d think the tech would have tested his work.
