Passerelle
Forum Name: 311 / 312 / 315
URL: https://www.myhanse.com/forum_posts.asp?TID=15256
Topic: Passerelle
Posted By: PASSION IV
Subject: Passerelle
Date Posted: 18 July 2025 at 10:49
Bonjour,
Je viens d'acquérir un Hanse 315. Mon ancien bateau avait un cockpit ouvert, et sur le 315 il m'est difficile de monter à bord une fois que la plateforme est remontée. J'aimerais savoir si d'autres propriétaires ont envisagé de poser une passerelle ou un autre système, vérin hydraulique avec télécommande par exemple.
Merci par avance de vos retours.
Hello,
I have just bought a Hanse 315. My old boat had an open cockpit, and on the 315 it's difficult for me to get on board once the platform is up. I'd like to know if other owners have considered fitting a gangway or another system, such as a hydraulic jack with remote control.
Thank you in advance for your feedback.
Hallo,
Ich habe gerade eine Hanse 315 erworben. Mein altes Boot hatte ein offenes Cockpit, und bei der 315 ist es schwierig, an Bord zu kommen, wenn die Plattform hochgezogen ist. Ich würde gerne wissen, ob andere Eigner eine Gangway oder ein anderes System, z. B. einen Hydraulikzylinder mit Fernbedienung, in Betracht gezogen haben.
Vielen Dank im Voraus für Ihre Rückmeldungen.
Chantal
Posted By: JZ&Dancing Lady
Date Posted: 08 September 2025 at 01:23
The 315 has about 1 meter of free-board so it can be challenging to climb aboard. In my current marina... the docks are only slightly above the water at high tide.  And Yes, climbing aboard and stepping over over the lifelines is not easy. I hold on to the backstay when climbing aboard and that seems to help a lot. I always get on first and then lower the stern platform for guests...  So far I am managing this but the idea of a gangway is interesting. Another idea is to put a step or two on the dock and that may be easier. Good luck and if you find a solution please post it.
Bonne chance und gluck.
JZ
Love 2 Sail
JZ
Posted By: Dubs2021
Date Posted: 08 September 2025 at 22:17
We have a 348 with a "gate" where the life lines unclip, so it's easier to climb aboard. Still, even at a medium height dock, it's too far of a step for my wife, so we use a FenderStep. I adjust its lines so it hangs about halfway between the gunwale and the dock. It lasted 4 years before an air leak in the seam deflated the fender. Time for a new one, bought via Amazon, arriving today! Link:   https://danfender.com/c/products/fender-step" rel="nofollow - https://danfender.com/c/products/fender-step
Hugh
Date Posted: 09 September 2025 at 01:33
Hugh,
We have a two step version of this type of fender step which we often use when we are alongside which works very well. They are a bit more difficult to find in a chandlery as they don't seems to be stocked as often as the single step version. We used the blue "ladder" type with 4 steps but they always seems to tear at the top.
