Defect display for fuel level water level and volt
Forum Name: 415/418
URL: https://www.myhanse.com/forum_posts.asp?TID=15258
Topic: Defect display for fuel level water level and volt
Posted By: Erttre
Subject: Defect display for fuel level water level and volt
Date Posted: 19 July 2025 at 07:58
I have had some rain entering the saloon window on the port side. The water has run down the instrument panel and circuit board. After this I only get access to fuel level, water level and voltage if I turn the main switch for the service batteries off and on, and immediately after press the buttons by the display. After that the buttons do not work. Does anyone have any advice hiw to fix this?
I have sprayed the connections with contact cleaner. Best regards Torbjørn/Daphnia X
Date Posted: 19 July 2025 at 12:11
This is the tough one. Read these threads and possible solutions
https://www.myhanse.com/pan-pan-loss-of-autopilot-and-rudder-control_topic15135.html " rel="nofollow - https://www.myhanse.com/pan-pan-loss-of-autopilot-and-rudder-control_topic15135.html  ;
https://www.myhanse.com/why-i-should-have-replaced-earlier-the-wurth-panel_topic15184.html" rel="nofollow - https://www.myhanse.com/why-i-should-have-replaced-earlier-the-wurth-panel_topic15184.html
