RMC Lewmar swing thruster
Forum Name: 400
URL: https://www.myhanse.com/forum_posts.asp?TID=15285
Topic: RMC Lewmar swing thruster
Posted By: Jansteff
Subject: RMC Lewmar swing thruster
Date Posted: 06 August 2025 at 15:31
The pin that connects the piston to the retractable part is broken on my thruster. I believe it is called a shear pin—similar to the one on the propeller. However, I haven't been able to source the correct pin, and I'm currently using a stainless steel bolt, which may not be ideal in the long run.
Does anyone know which pin I should order?
Posted By: Ggerrit
Date Posted: 06 August 2025 at 17:45
RMC
Rybeck Marine Components AB
Korsviken 217
45991 Ljungskile
Sverige
Mikael@rmcab.se
H400 2008 2 cabin
Posted By: Wild
Date Posted: 06 August 2025 at 19:21
Lewmar actuator shear pin
185TT PARTS NUMBER 55910072
Wild and Wet
Belgium
545e#268
Posted By: Bendi2s
Date Posted: 13 September 2025 at 21:33
Had the same issue, but found shear pin at boattec.net. Same pin for model 140 and 185.
Good Luck
B
Posted By: Jansteff
Date Posted: 14 September 2025 at 07:20
Thanks Bendi
