Service battery charging issue
Forum Name: 370 / 375
URL: https://www.myhanse.com/forum_posts.asp?TID=15290
Topic: Service battery charging issue
Posted By: Big Al
Subject: Service battery charging issue
Date Posted: 08 August 2025 at 16:51
I am seeking advice regarding issue I am having regarding charging my service battery bank. When I start engine and leave in neutral I can see that my service batteries are receiving charge. However when I am under way on motor no charge is going to my service batteries. Starter motor is less than a year old and Service batteries are only 2 years old. Any advice would be much appreciated
Alan
2009 Hanse 370E
"Vohirana" Hanse 370E Hull Number 55
Date Posted: 08 August 2025 at 19:24
There maybe a problem with your battery combiner, it works to combine  engine and service batteries if the voltage at alternator side exceeds a certain value, such as 13.2V or around it depending on the model. You can check if the combiner is open or close when you say service bats are not receiving the charge.
Posted By: Big Al
Date Posted: 09 August 2025 at 05:49
Thanks for that Marcella.
Posted By: Borjebus
Date Posted: 09 August 2025 at 12:17
Make and Avanced Search, Any date, for"
Alternator not charging house battery", and you will probably have the answer.
