Seats
Forum Name: 400
URL: https://www.myhanse.com/forum_posts.asp?TID=15357
Topic: Seats
Posted By: carrierjason@mac.com
Subject: Seats
Date Posted: 11 September 2025 at 12:17
I just bought a 400e, there is no good place to sit while cruising.  Has anyone seen a good solution for this.
Posted By: Ratbasher
Date Posted: 11 September 2025 at 18:45
We got a couple of these.  Ratchet mechanism means you can bend it to whatever angle you want and with a slip-resistant base can place it on the side seats or behind the helm.  You can also use it on the coachroof or foredeck for those times when a little marital separation might be useful.....
Posted By: Arborist
Date Posted: 12 September 2025 at 13:14
i have those as well and use them while helming also, i have a small tag line on them with karabiner so they don't blow away
alternatively you can get cushions that slip onto the stanchion wires to lean against
while in marina this year i actually used the saloon L shaped rear cushions in the same position as the picture, pure luxury!
hanse 400
2007
no 244
Date Posted: 12 September 2025 at 14:42
Posted By: Mark_J1
Date Posted: 15 September 2025 at 22:20
I recommend the largest beanbag you can tolerate onboard. Ours gets used in many locations to form a comfy spot!
Date Posted: 15 September 2025 at 22:30
I think I am going to get the lifelines replaced with hard stern stations with chairs cut out.
