Broken Mast Stand
Forum Name: 311 / 312 / 315
URL: https://www.myhanse.com/forum_posts.asp?TID=15374
Topic: Broken Mast Stand
Posted By: on y va
Subject: Broken Mast Stand
Date Posted: 29 September 2025 at 16:29
Hello,
I’m writing you regarding my technical issue of my Hanse 311. The ship was bought in 2002 by the previous owner.
 I was wondering if someone have more technical information about my ship? Between the deck and the keel is a powl (the mast stand). In the bottom, cracks are appearing in the fiberglass.
 For now, my impression is that the damage is limited to the fiberglass of the stringers.
 Inside of the damaged Springer is a wooden Beam. Approximately 5 times 8 centimeter, that stretches to both sides of the schip. The beam seems fully in tact after checking it with a endoscopy camera and is bone dry.
 I’m surprised to see that the mast support stops on top of this beam and not on the keel. We are able to fit our hand between the beam and the haul / keel. We ‘re really surprised by this construction.
 To my (and my technical harbor friends) knowledge a mast support should always rest/ put compression from the mast on the keel. Could someone tell me if our interpretation of the constitution is correct? and what the filosofie behind this is? I put also 2 drawings in the attachment, are they correct? Is this on all the Hanse 311 and 312?
Also I have carefully inspected the deck around the mast foot and could not find any cracks or visible deformation.
kind regards, Nico
Posted By: Jesper2603
Date Posted: 05 October 2025 at 16:48
Hello,
I have the exact same problem/question. I have bought the 311 two months ago.
Could this deformation come from a grounding?
Is there a need for a repair?
Brgds Jesper
Posted By: Forth2
Date Posted: 20 October 2025 at 21:27
I think the rationale of the design is to spread the load to larger area of
the bottom. The mast force cannot be directed straight down because
all of the keel is located aft of the mast support.
Only the tip of the keel sole extension is located straight under the mast support.
The beam under the mast support flexes a little bit when it is loaded
and therefore the gelcoat cracks. As long as the beam GRP does not fail
I don't think there is a need to repair it.
Posted By: FrankS
Date Posted: 21 October 2025 at 16:59
on your photos it seems that in the past someone has applied an extra (grey) layer of polyester.Do you know the reason for that ? Is it possible that there has been a grounding resulting in more cracks in that area?
Hanse 345 2016 "STYX"
Date Posted: 21 October 2025 at 18:40
The reason for this design is that the hull is supporting the keel. Not the other way around. The keel is hanging from the hull. If the mast load pushes at the single point at the keel it will only increase the stress at that point. Instead, the wooden beam spreads the load to the rest of the hull and avoids putting more stress at the keel. The best place to transfer the load is as close to the shrouds as possible. That is where the downward forces start.
Posted By: on y va
Date Posted: 21 December 2025 at 18:46
Thank you all for the responses. November was a busy month but of course the 311 was also on my mind. Unfortunately Dutch wintertime is too cold to do polyester work outside. Therefor I have a lot of time to research.
@Jesper, I can imagine grounding(s) can cause this problem. In my first poste you see the hole nest to the keel bolt (on the up side down picture, I’m not that good in uploading on the form yet). In my opinion this is the weakest point in the construction. This was confirmed by my polyester shop. I would advise everyone where this part isn’t deformed yet to reinforce it with epoxy/polyester. Preventing this seems the best solution to me. Unfortunately to latte for me. Can you poste pictures of your keel situation?
Towards your second question, I’m planning to repair it. I’m sailing a lot on the Grevelingen lake in the Netherlands, it can be shallow so sometimes soft groundings can happen.
@Frank, the extra (grey) layer seems to be a thick layer of paint. It also looked a bit suspicious to me but. Every bilge segment has it and the paint seems to continue under the transducers and under the metal plates that hold the keel. Therefore I like to believe its not a repair. When I’m going to repair my structure I have to open up some grey paint and the truth will come out.
@Forth and Arcadia, I agree to your philosophies of the ships construction design.
-          The keel is hanging from the hull,
-          The GRP beam (stringer) gives strength to the hull
-          The wooden beam transfers the pressure of the mast towards the shrouds. So the pressure of the mast is not on the keel.
I’ve been to a boatyard and they expect that the wooden beam is rotten and needs to be replaced. The complete GRP cross around the mast stand should be renewed including de wooden beam that supports the mast. Fixing cost: unrealistic for a young sailor like me.
 Since the wooden beam is bone dry I don’t believe in this rotten beam story. More about that in my next poste.
Posted By: on y va
Date Posted: 21 December 2025 at 18:52
Recently we opened up a bit more of the polyester and we could se more of the structure.
uploads/7095/open_1.pdf" rel="nofollow - uploads/7095/open_1.pdf
the roof the pole is bolted on and no cracks anywhere  uploads/7095/open_2.pdf" rel="nofollow - uploads/7095/open_2.pdf
uploads/7095/kom_4.pdf" rel="nofollow - uploads/7095/kom_4.pdf
uploads/7095/kom_4.2.pdf" rel="nofollow - uploads/7095/kom_4.2.pdf
In pdf kom_4 you can see that the gap under the beam, above the beam there is some GRP in the shape of a square recess that holds the RVS pole above the wooden beam. Since wood can bent I believe this beam went down 3 to 6 millimeters wat results in extra stress on the GRP.
I’m planning to reinforce the square resess (bleu arrow) . By ending more GRP to it so I can increase the strength of the recess and connect it better to the wood. Since I’m building this GRP up anyway I’m going to pack the wood as good as possible and create a soled connection between the wood and the GRP structure of the boat (red arrow).
The last part of the repair will be reinforcing the length wise springer with wooden slats wrapped in polyester (the green lines). I’m not sure yet if I’m going to do this on the in or outside of the springer. On the inside its hard to get a clean bonding surface. But I can connect it to my first repair (red square) what will give a strong connection. On the outside it will be a bit easier but won’t look nice.
To help this 23 year old boat with its injury I’m planning to give it a bit more extra strength. In blue lines I tried to show how I’m planning to add to GRP (wood inside)  triangles that will make a connection between the square recess and the hull to add some extra strength.
Posted By: on y va
Date Posted: 21 December 2025 at 20:16
I’m not starting a monologue but I’m not afraid to add some extra strength since I found pictures of other 311’s that have more springers than mine.
and below is mine. seems like some have extra springers (red lines)?
Does anyone have pictures of there hanse 311 or 312 without floorboards?
Posted By: sgrhma2
Date Posted: 21 December 2025 at 22:27
Having looked at you photos, I think you may be unduly worried. The grey paint is actually flow coat, which is just resin that is painted on to cover and tidy up the layup and tabs that the floor frame is bonded in with. It has no glass fibre in it to provide reinforcement and is just decorative. Looking at all the other sub floor recesses, there is absolutely no evidence of stress cracks, which would suggest the boat hasn’t been grounded severely which gives stress cracking or failure usually at the front of the keel attachment where it will have been pulled down and at the back where the rear of the keel is pushed up into the hull. The areas in your photos show absolutely no evidence of this. If it has been grounded that hard there should also be evidence on the keel itself.
The wood underneath the frame has obviously never been bonded to the inner frame and as such isn’t really providing much in the way of support for the GRP frame the mast sits on. What the wood is for, I suspect is to support the inner moulding at approximately the correct height before the mast support pole is fitted and the frame then bonded in with GRP tabs. To do this the frame with most of the furniture and engine is set in place and probably tabbed in place at the stern of the boat and around the engine. The deck is then placed and bonded onto the hull. Once the deck is fully attached, the mast support pole is fitted by jacking between the inner frame (which is still not bonded to the hull and is sitting on the wooden beam) and the inside of the deck. This pushes the frame down sufficiently, bending the beam slightly, to insert the mast support heel into the recess in the floor frame and the reinforcement in the deck for the mast. The bolts you see I would expect are the same ones that locate the deck mounted mast fitting. Once the pole is in place, the jack is removed, the GRP supported by the beam, push firmly upwards against the mast support pole. It is at this point that the front of the internal frame is then tabbed fully to the hull, ensuring a perfect fit for the mast support pole and spreading the mast loads across the hull through the internal frame and the GRP tabbing bonding it to the hull. From this point onwards the wooden beam is irrelevant, it isn’t doing anything except baffling owners that find it. The GRP frame is significantly stronger and stiffer than the wooden beam. It’s only still there because it’s too difficult to remove it once it’s done it’s job of supporting the frame and mast pole during production. As for the cracks at the base of the pole, these appear to be only in the the gelcoat of the frame, not in the GRP matrix. Like flow coat, gelcoat is only resin and has no reinforcement in it. The gelcoat cracks I would expect occurred when the frame was being jacked down to fit the pole and don’t appear to be anything to worry about.
You do now have a bit of work to do repairing where you’ve opened the frame up a bit, but it’s only minor and as you said should be done using glass and epoxy.
I hope this was useful and if you want to discuss further feel free to pm me.
Simon
Posted By: on y va
Date Posted: 28 December 2025 at 18:27
Hey Simon,
Thanks for your explanation, this makes the situation a lot clearer. Today I have stripped away the delaminated and shattered GRP to a point where it is somewhat hard. I'm afraid the cracks at the base of the pole are a bit bigger than we hoped.
What I found was this strange build-up of grp, gelcoat, grp and gelcoat. What I found was this strange build-up of grp, gelcoat, grp and gelcoat. The piece we have taken out shows this well. I can’t imagine this is good for the strength.
Hopefully I can get some more advice about this repair?
