Eau salée sous plancher cabine babord arrière
Forum Name: 370 / 375
URL: https://www.myhanse.com/forum_posts.asp?TID=15431
Topic: Eau salée sous plancher cabine babord arrière
Posted By: Lolo66
Subject: Eau salée sous plancher cabine babord arrière
Date Posted: 07 November 2025 at 13:18
Bonjour
Depuis cet été je trouve régulièrement un peu d'eau salée sous le plancher.
Je n'ai aucune idée de sa provenance.
J'ai laissé le bateau au port sans l'utiliser pendant plus d'un mois, j'avais mis du papier au niveau du compartiment moteur mais a priori c'est sec de ce côté.
D'où peut-on provenir cette eau salée ?
Posted By: alettaenmarcel
Date Posted: 07 November 2025 at 22:21
Keel bolts
True hulls
Search in those directions.
Posted By: Lolo66
Date Posted: 08 November 2025 at 10:54
Ça ne peut pas etre les boutons de quille car pas de fuite de ce côté, de plus la cabine arrière est situé au dessus du point le plus bas
Posted By: Yoda
Date Posted: 10 November 2025 at 20:01
Look very carefully around the hull valves in the heads compartment. I found the skin fittings to have been fitted poorly and it found it's way both under the saloon floor between galley and heads, and also through into the port aft cabin.
When I removed the skin fittings I found the holes to be over size, oval and not round, and lacking sealant in places.
Yoda
Posted By: Lolo66
Date Posted: 10 November 2025 at 22:16
Merci.
Les passes coques ont été changés en 2022.
Posted By: Borjebus
Date Posted: 11 November 2025 at 11:38
There is a topic "A WARNING to ALL Hanse owners" wher I have a post in this matter. My solution was to install a bigger through hull.
