Wuerth DC-panel TEV0605
Forum Name: 345/348
URL: https://www.myhanse.com/forum_posts.asp?TID=15434
Topic: Wuerth DC-panel TEV0605
Posted By: ynotahanse
Subject: Wuerth DC-panel TEV0605
Date Posted: 10 November 2025 at 21:27
I am hoping that someone can advise me on the fresh water tank sensor not working on a Hanse 348. Does not read the fresh water tank level.
The sensor is the 2 pin 180 ohm type which is connected to connector 6.1 (wasser1) on the dc panel. The service manual for the Weurth DC panel states:
"2 Coding Plug The water level can be read over a 5-wire sensor or a 2 wire 3…180 ohm sensor. By default a 5-wire sensor is assumed. If the 100% value of the 5-wire sensor of the connector will be reconnected to the ground, is no longer the 5-wire sensor in use but the 2 wire 3... 180 ohm sensor. This accounts for both water sensors, independently from each other. " - meaning short pins 1 and 5
But the DC panel on our Hanse is not a 5 pin, its a 6 pin (3x3)
does anyone know what pins to short on this type of DC panel layout?
