Removal of Galley
Forum Name: 350
URL: https://www.myhanse.com/forum_posts.asp?TID=15442
Topic: Removal of Galley
Posted By: JMN
Subject: Removal of Galley
Date Posted: 17 November 2025 at 08:36
Dear Hanse sailors,
on our 2008 Hanse 350, the bonded connection between the inner liner and the hull has unfortunately broke and come loose in a few areas. To repair it, I need to remove the entire galley in order to take out the floorboard underneath.
Has anyone here done this before and could share some tips or experience?
Thanks and best regards,
Malte
Posted By: Ture
Date Posted: 17 November 2025 at 10:38
Hello fellow seafarers,
Yes, unfortunately, I have experience with this type of damage.
The repair is very complex. The furniture doesn't need to be removed.
The work is difficult to do yourself.
Greetings from Hamburg,
Ture
Posted By: Brufan
Date Posted: 17 November 2025 at 16:18
Most floor panels can be removed without taking funiture out.  It's tricky but doable
Bruno
hanse 355 - 57
S/Y Spicy Ginger
Posted By: JMN
Date Posted: 17 November 2025 at 17:01
Unfortunately, one of the larger cracks is located right behind the seawater valves under the sink. To get access to that area, the floorboard beneath the galley unit needs to be removed, and in my view that means the entire galley has to come out. Or am I mistaken?
@Ture: I’ve sent you a PM — since you’re also based in Hamburg, maybe we can have a quick chat directly? I’d appreciate any advice :)
Posted By: Ture
Date Posted: 18 November 2025 at 09:51
Moin Malte,
du erreichst mich unter
ture24@t-online.de
