Hi Andrew, I have a 3 cabin 370 and I keep the outboard on a pad on the pushpit. As Iain has pointed out, electric ones are the lightest around and therefore the easiest to lift on and off the back to the boat. In my opinion the next best are the old 2 stroke Yamaha 2hp or Suzuki 2/2.2hp. They are lighter than all of the current small 4 strokes and in the unfortunate event of them taking a swim can be recovered and running again in less than 15 minutes (I’ve recovered 2, one of my own and one for a boat anchored in the western isles). To facilitate lifting on and off the boat I use a Velcro dive cylinder handle that is just attached around the power head. This allows you to easily lift the outboard and makes it significantly easier for a crew member to hand it to you in the dinghy. As regards not having fumes from an outboard, you should always turn the fuel off and screw down the tank vent. Once this is done run the engine until it cuts out, using the choke for the last few seconds to get the last of the fuel out of the carb. Once this is done lift the outboard on to the back of the boat and place it upright on a mounting on the pushpit. This is to let it drain all of the sea water out of it. When lifting or storing an outboard it is always best to keep it upright. It is essential that the powerhead is always higher than the gearbox / prop, this is to ensure no water can run up into the engine and destroy it. If you keep the outboard on the pushpit that’s you finished. If you are storing it below have a bracket made to keep it upright, but leave it on the back of the boat until just before you sail. This way it lets the engine drain as best as possible and for fumes and fuel vapour to disperse, this minimises smells in the boat. One person I know fitted an engine blower on a flick switch so that if he smells anything from his walk in locker he can suck the fumes out of the boat. Outboards should never be stored on their side, it increases the risk of internal corrosion and of leakage of oils and fuel. NEVER START AN OUTBOARD IF IF IS NOT IN THE WATER OR WITH A COOLING WATER ATTACHMENT FITTED. Running it dry you will destroy it in seconds!
If you are considering getting a small 2 strokes there are loads of good ones still around, if you want to know the main issues I’ve found with the 2hp Yams and Suzukis PM me.
Hope this was useful Simon
