Teak decking issues
Forum Name: 311 / 312 / 315
URL: https://www.myhanse.com/forum_posts.asp?TID=15537
Topic: Teak decking issues
Posted By: BarcombeBoy
Subject: Teak decking issues
Date Posted: 02 March 2026 at 15:29
Hello.
My sailing buddy and are considering buying a Hanse 311. However the boat we are interested in has a number of issues (not least osmosis and leak into the cabin!) including one that is a bit of an unknown quantity to us ... the teak decking.
The decking appear to be original, is screwed down and doesn't give the impression it's ever been cared for. It's coming up in at least two places and the sealant between the boards does not look great either. The sealant under the gunwales, which I'd guess is required to stop ingress of water under the boards (?) has not been maintained and is peeling off. Indeed, most of it isn't doing any proper sealing and doesn't look like it has been for some time.
I'm trying to understand our options here and would welcome any input from people with knowledge and/or experience of the Hanse teak deck.
These seems to be the options:
1) Replace it - nope. Silly expensive
2) Replace it with fake teak - nope, still too expensive to consider
3) Renovate it - with possibility that the job that will end with us sanding it all, taking it up, re-laying it and resealing it - nope, far to torturous and will probably end up looking quite crap, and I understand the teak boarding may only be 7mm thick which may preclude sanding
4) Repair just the boards that are loose - might not be too hard , but may be never ending and will deck probably require attention again next year, the year after, the y... etc etc
5) Pull up the whole lot, fill the screw holes and apply non-slip paint
To me the last option seems about the only viable option on a 25 year old boat but I know nothing. I have no love of teak and the maintenance it might need and even less for fake teak.
Any input would be very appreciated.
Simon
Posted By: Rhum coco
Date Posted: 02 March 2026 at 16:58
Bonjour j'ai un 385 avec le pont en teck de 2012 acheté en 2019 . Le bateau présentait des fuites au niveau des esuipets quand il pleuvait beaucoup ou au nettoyage u jet d eau . J ai trouvé la cause : les nables eaux noires et entrées eau douce n ont pas été correctement scellées l eau s infiltre entre le teck et le plancher. Après démontage et si a en grande quantité tout autour , tout est ok étanche . Quelques lattes en avant se décollaient . J ai enlevé les joints de sika  ,soulevé les lattes , nettoyer et recoller avec du bon sika. Depuis 7 ans tout ok . Nettoyage : j ai dépensé une fortune avec le tract wonder , bon résultat, maintenant je prends du savon noir liquide tout aussi bon résultat et beaucoup moins cher 😂
Posted By: perry
Date Posted: 02 March 2026 at 20:32
Hi Barcombe Boy. I have a H312 [2007] with teak cockpit, its original, and its bonded down with Black Sika type adhesive, its thin but perfectly servicable. I doubt that your 311 with what appears to be screwed down teak was originally screwed,  no boat builder over  last 20/30 years uses screws to fix down teak, its always adhesive  bonded. It never made sense to perforate a perfect GRP molded waterproof deck [maybe with a balsa or foam core] with screws once suitable adhesives became common in yacht building.
Could it be someone has lifting teak, and tried to screw it in few places?, a bad idea.
Another observation on current boat building with teak is;  due the high price and lack of supply the teak laid in a deck is very thin and doesnt last long if you sand down. In fact its so thin it could not be screwed down.
Bear in mind on old Halberg Rassy yachts with screwed down teak decks the teak was thick enough to screw and thick enough to put plug on top of screw to hide screw head.
Good luck with your boat search.
Current Yacht Hanse 315 2007
Date Posted: 03 March 2026 at 10:25
Thanks very much for your reply Perry. It is appreciated.
I've dug out some photos from the advert. It looks like the teak deck was screwed down when it was installed in the boat, which I've no reason to believe was not in 2000 when the boat was made. You can see that the screws are capped, although many of the caps seem to have dropped off. If, as I've read, the teak is likely to be only 7mm deep this doesn't leave a lot of wood for the screws to hold.. and may be the reason a couple of portions of it are coming up. My initial feeling is we ought to price in removing the teak, filling the holes and painting the deck. However, I have no idea how laborious it will be, whether it's a reasonable idea and how the screw holes might affect the integrity of the deck. Any comments welcome.
Teak decking screwed into fibreglass grp
