Lewmar pod for Raymarine C80
Forum Name: 411
URL: https://www.myhanse.com/forum_posts.asp?TID=1892
Topic: Lewmar pod for Raymarine C80
Posted By: samba
Subject: Lewmar pod for Raymarine C80
Date Posted: 28 February 2008 at 21:32
Hello all,
Does anyone know if the radar multi pod of lewmar  http://en.lewmar.com/products/index.aspx?lang=1&page_id=296&part_number=89400274 - http://en.lewmar.com/products/index.aspx?lang=1&page_id=296&part_number=89400274  can be attached to the steering system of the Hanse 411. Has anyone done this?
I am planning to replace my current pod with the radar multi pod and install a C80, the autopilot and a Simad VHF handheld in the pod.
Michiel
existing%20pod
Posted By: Nereide
Date Posted: 29 February 2008 at 08:12
Michiel,
I have a wide lewmar pod for all displays, but the only thing to check is whether the pedastal guardrail width (stainless support on your photos fits to spec of your new pod. i presume that as both are lewmar, this shouldn't be a problem.
reading the product sheet, it says  FOR 304MM - 12"   guardrail ONLY.
stephen
Posted By: Alex Faber
Date Posted: 01 March 2008 at 21:26
Michiel,
Please be aware of the fact that your compass will not give an accurate reading anymore if your vhf (or any other device with a loudspeaker) is so close to it.
s/y eMotion (H430e #24)
Posted By: samba
Date Posted: 02 March 2008 at 09:16
Alex,
Good remark. I haven't thought of that. I will look for a different position.
Thanks,
Michiel
Posted By: samba
Date Posted: 24 March 2008 at 21:30
Well I found out that the radar multi pod of lewmar does not fit. The tube is too small. With some additional work and some help of friends I got it installed in the end.
We have cut the top of the tube, extended it 170mm en put it back together. I am quite happy with the end result.
Here are some pictures of the work done:
