Boom light
Forum Name: 461 / 470
URL: https://www.myhanse.com/forum_posts.asp?TID=2799
Topic: Boom light
Posted By: gertha
Subject: Boom light
Date Posted: 11 February 2009 at 22:45
Hello,
I believe the 46/7 has a sexy boom light as an option. I wish to install said piece on a 37, any clues on how it fits , who makes it and how the wire gets around goose neck appreciated.
Simon
Swanned off
Posted By: leemind
Date Posted: 12 February 2009 at 09:43
I have the above mentioned light, but it wasn't on the boat as standard and Dave from Aztec Marine retro fitted it.  The fitting is nothing special at all, just a low profile fitting screwed into the boom and at the gooseneck it exits the boom on a connector which can be disconnected and then enters the mast via a little hole with a grommet.
It really would be a simple job to add one.  I'm going to try and go down this weekend and if I do I'll take a couple of pic that may help.
David
461#028
Grand Cru
Hanse 461#028
Posted By: John Allison
Date Posted: 13 February 2009 at 11:29
Hi Simon,
We also have one and ours was the factory option.
As David explains - it is nothing special.  Aluminium round holder for a MR16 halogen globe fitted into a hole drilled into base of boom.
The power lead exits the boom before the gooseneck and 2 pin screwed plug into the mast.
One suggestion before you fit is to swamp the rear wiring / connections with liquid plastic - the kind of stuff that will insulate.  We find the hole drilled to recess the lamp into the boom acts as a drain hole for just about all water coming from inside - and unprotected - we found our globes / connections eventually corroding.
JOHN
Posted By: taduka
Date Posted: 13 February 2009 at 14:45
hi Guys
Today it'a an LED strip light which fits neatly in the groove. you can retrofit for about Euro75 for the led light..
Shawn
Posted By: panos
Date Posted: 13 February 2009 at 18:16
I have also LED boom lights on my boat. (3 sets of 3 LED's each. They are very powerful and very easy to install. Since they are flush (surface) mounted you just need one hole for the cable and two small ones for the screws.
 Since I was concerned that after a while one gets destroyed I got a spare which I photographed:
general view
detail on brochure
specs
Panos
Hanse 630e - selling her -
Posted By: tobo
Date Posted: 14 February 2009 at 15:16
There is in fact a sexy LED lightning bar that fits into the boom. (Doesn't get damaged if booms touches the waves Smile) Can't tell you the brand, it's on the boat. Cabeling goes through the boom with a plug on the mast, probably preinstalled as there is already a switch on the board. (at least on a 470) Upsy Daisy haven't seen Panos pro comment; he knows everything. That's the one I meant.
Update: Now it's mounted. But it needed some work with the angle grinder to fit it into the slot(Uf!)
Thomi
Date Posted: 16 February 2009 at 13:52
Brilliant upgrade.  (Yes - pun intended).
Will try to source for UK and replace our conventional halogen MR11.
Thnks Panos / Tobo
JOHN
Posted By: Richard108
Date Posted: 16 February 2009 at 14:53
The web site for the manufacturer of theses 1 watt bars is
http://mp.yvora.nl/index.php?ID=47 - http://mp.yvora.nl/index.php?ID=47
They are also available I see in a 3 watt version so perhaps instead or 3 bars of 1 watt LEDs that Panos has installed a better alternative would be to put in 1 x 3 watt white and 1 x 3 watt red.  A dimmer may be a good option too for the red lights at least.
http://mp.yvora.nl/index.php?ID=48 - http://mp.yvora.nl/index.php?ID=48
The following list provides the distrubuters in each country though I suspect that they are not available in Australia (and perhaps elsewhere) as they are not listed on the whitworths website.
http://mp.yvora.nl/index.php?ID=5 - http://mp.yvora.nl/index.php?ID=5
Regards Richard
Pittwater, Sydney, Australia
Date Posted: 16 February 2009 at 15:39
The only places on the web that I could find that may sell them are
USA http://www.drsa.com/high%20power%20led%20lights.html - http://www.drsa.com/high%20power%20led%20lights.html
Netherlands http://www.asabootelectro.nl/cgi-bin/scripts/shop_products.cgi?cat=3647&self=108 - http://www.asabootelectro.nl/cgi-bin/scripts/shop_products.cgi?cat=3647&self=108
Sweden http://www.fdecker.se/ - http://www.fdecker.se/
Regards Richard
Posted By: gertha
Date Posted: 16 February 2009 at 19:18
Hello,
John, or anyone, if you can find them in the UK, please let me know, it looks like EC Smith are the wholsale outlet; but not in there regular catalogue.
Simon
Swanned off
Date Posted: 22 February 2009 at 10:18
Hi Simon,
Any of these parts are available through Force 4 or Nick Cox in Lymington or indeed, they say any other chandlers around the Hamble.
JOHN
Posted By: Infliximab
Date Posted: 01 April 2009 at 10:41
See also the Sparcraft LED boom light, no. 43020031214,
http://www.sparcraft.com/uk/technical_support/technical_brochures/performance_range/fichiers/feu.pdf - http://www.sparcraft.com/uk/technical_support/technical_brochures/performance_range/fichiers/feu.pdf
Tschüss,
Infliximab (ex RSchrHH)
_________________________
Hanse 370 #316
located near Flensburg, Baltic Sea
http://maps.google.com/?ie=UTF8&ll=54.94371,10.004425&spn=0.460656,1.450195&t=h&z=10
Posted By: psousa
Date Posted: 07 July 2021 at 12:18
do you know what light/bulb is this (the one close to the book letters)?
https://ibb.co/550LRTG" rel="nofollow"> https://ibb.co/GscCkhn" rel="nofollow">
Posted By: JonB
Date Posted: 08 July 2021 at 19:08
Alternatively !
And yes I did have to cut a slot and work on the edges.
The circular hole at the back is the where the original fitting went
Jon B
470e
Posted By: psousa
Date Posted: 15 July 2021 at 09:29
Looks nice!
In my case, at the end, I’ve found that all those light parts belongs to a single bulb: GU4 type
So I’ve kept the original fitting.
I’ll replace with a GU4 led compatible bulb in the future.
https://ibb.co/58K7V1Y" rel="nofollow">
https://imgbb.com/" rel="nofollow - image uploader
