FUEL EFFICIENCY
Forum Name: 311 / 312 / 315
URL: https://www.myhanse.com/forum_posts.asp?TID=333
Topic: FUEL EFFICIENCY
Posted By: tony1
Subject: FUEL EFFICIENCY
Date Posted: 18 October 2005 at 17:06
I have just ordered a new 315 for delivery next year.  It seems the 315 is the only Hanse model without a fuel gauge, and Hanse Uk quote £495 to fit one.
1.  Does anyone have information on fuel efficiency - i.e engine running time per litre of diesel?
2.  Has anyone fitted a gauge themselves?
Otherwise the boat seems to have everything, except a grill on the cooker - apparently the Germans do not realise the importance of toast!
Kittiwake 315-461 2006 Grey Hull   Swing Mooring on Beaulieu River
Posted By: Scotch Mist
Date Posted: 18 October 2005 at 18:15
Hi Tony
I bought a brand new 312 last year. I ordered a fuel guage as an extra to be fitted by the dealer. I can assure you it did not cost anything like the figure quoted - much cheaper. I shall'nt say how much but either they sold it at a loss or there is a good profit in it for the dealer at the price you're referring to. since I was there when they installed it, I can say it took 2 guys about 2 hours, though this is probably longer than it should, because they had to go away to get a circular hole cutter and really it was only a one man job anyway!. my suggestion is either see if you can negotiate with Hanse or alternatively have a word with a local marine electrician for an alternative quote.
With respect to whether you need it. I think the engine must be fairly efficient. It takes a lot of motoring to empty the tank. I'm always surprised at how little fuel has been used whenever I look at the guage. Against that I dont think you could conveniently 'dip' the tank - would require a flexible rod and standing on the side deck. It is very comforting to know how much fuel you've got - diesels dont like running dry- bleeding injectors etc! I think the comfort factor makes it a must for me!
Andrew
Posted By: susie
Date Posted: 18 October 2005 at 20:24
Based on two summer's worth of experience with a 312, the average consumption is pretty close to 1 liter/hour. This is based on sailing habits of only motoring in and out of harbours, and occasionally motoring on calm days at 3000 rpm.
Regards,
Susanne
Date Posted: 18 October 2005 at 21:11
536 Hours now on the clock. Volvo 2020MD standard 2 bladed prop.Standard fin 315 Hanse
Average is 1.66 litres over whole period .normally do about 5.9 Knots at 2800 revs. In the Dutch canals over 2 lots of 2 week holidays we did a bit less - about 1.3 litres - averaging about 5.5 knots.
Highest consumption was in a severe gale when we could not carry main as 2nd reef was too big. Consumption went up to about 1.9/2.0 litres per hour. But we were really struggling in head wind.
Posted By: iemand
Date Posted: 19 October 2005 at 12:26
I think 1-1,5 is the effektive Yanmar 2GM20 fuel consumption. You need to remember that you maybe have a diesel heating. Therewith you don't have a hour counter.
I would talk to a local service partner because the gauge cost's 100-200€ (a good one) and it shouldn't take longer than 2 hours.
I think about building in one with a switch also for a water gauge.
Regards Thomas.
Posted By: mqh7
Date Posted: 19 October 2005 at 18:29
I bought a brand new 311 in 2002 (hull #101) and it did come with a fuel gauge.  It is down below next to the battery charger panel.  It even has back lighting so I can see it in the dark.
I burn about 1 to 1.5 liters per hour depending the seas and the RPM's I am at.
Matt
Posted By: gertha
Date Posted: 19 October 2005 at 21:57
Hello
There is a formula for liters per hour over horse, however I have lost it. I think 25 hp is 4 lts or one US gal.
I work on 2 lts per hour,so clock hours on fill up and always have plenty in reserve, when tank is in theory low.
Simon
Posted By: BlueMan
Date Posted: 20 October 2005 at 15:56
You'll find a fuel consumption graph for the 3YM20 here....
http://www.yanmarmarine.com/products/pdf/GM_YM/3YM20_TechData.pdf - http://www.yanmarmarine.com/products/pdf/GM_YM/3YM20_TechDat a.pdf
Between 1 and 2 litres per hour fits with our year of experience with our 2GM20. We keep filling up too early as well since we don't have a fuel gauge either.
Regards,
Andrew
Posted By: Muscadet
Date Posted: 20 October 2005 at 17:27
Tony
I have a 3YM30 on my 312 and the fuel consumption figures at the lower revs seem to agree with those given on the Yanmar website that Andrew mentions above - i.e. between 1 and 1.5 litres per hour.
Without a fuel gauge I was always filling up early as well. The problem is that if you increase the engine revs to overcome a strong head wind the fuel consumption can go up to 3 litres per hour so you have to apply caution to any calculated consumption.
Last winter I fitted a plastimo fuel gauge and sender which from memory cost about eighty pounds. I fitted the sender unit into the tank access hatch which could be drilled off the boat and avoid getting swarf into the tank. The gauge itself I fitted next to (and wired into) the engine switch panel. The only problem I have is it tends to read low. So when the tank is full it reads just over 3/4 full. When it reads empty the tank is still over 1/4 full. I think this may be excessive resistance on the sender wiring so this winter I may try increasing the wire thickness. But the gauge does give an indication of what's left and currently reads on the safe side.
I put a similar gauge into the water tank.
Tank sender fitted to hatch
Sender unit in place
Fuel gauge in Cockpit
Hope this may be of help
Alan
Posted By: anti
Date Posted: 12 November 2005 at 21:43
Where is the tank situated?
Posted By: Muscadet
Date Posted: 14 November 2005 at 12:04
The fuel tank is under the double berth in the after cabin.
Alan
