Hi Joćo,
I would prefer to make my own package deal to have the best quality stuff on the market
When Hanse delivered my 531 #35 they already showed a tendency to select brands based on costs and then use types that I would select one grade more strong for serious sailing. Looking at the models that followed they continued in that direction, as only in that way they could decrease the selling price of this type (next to making things optional that used to be standard).
Just some remarks on the option list you mentioned
- I have not opted for the bow thruster, and after 4 years still wouldn't opt for one (took some time to get used to the boat size, when having sailed a First 41S5 before, but even getting in or out a marina box with a 90-degree wind is not a problem for a duo handed crew).
- 2 electrical winches is really nice (think of upgrading my port Harken winch, very easy to do since all wiring and switches are pre-installed anyway)
- Looked at the MDS slide car system of Selden, and would advise you seriously to consider a more appropriate system with an external rail connected to the mast groove and cars with Torlon roller bearings. Personally I consider Harken to be the best, and since it is a main component on your yacht it is worth to go for the best (having split tracks as Keith advised I considered as a nice to have, I did not opt for it because I do not feel like to add complexity (jamming risk) and wanted to spend the money on other nice stuff).
- Genua tracks; yes
- Hydraulic tensioner; of course
- battery pack; yes, probably the ones they toke out of the standard delivery anyway .
- teak on cockpit floor; looks much better and adds to safety
- 3 blade folding prop; yes, it is a sailing boat. I'm happy with my Yanmar with mechanical drive and 3 blade Gori, but also read the nice mailing under the subject "gori propeller" and "shaft/rudder vibration" where you will be overloaded with opinions.
- blind set; look at what is on the market, before going for the Hanse choice
- music installation with in/outside speakers; yes, but I would opt to make my own choice on both radio set and speakers (often rather personal what you like)
- Anchor etc; fully agree with Keith, the 25 kg is too light, and on top of that the Delta brand those not give the best results. Installed a Rocna 40 kg on my 531 just 2 month ago, and now use my 25 kg Plastimo Kobra-2 as spare. There is some mailing on this subject under "anchor fitting for 531" where I learned that on a 540 this anchor does not fit due the somewhat different canting construction, but a Rocna 33 does. Rocna has a nice website with also a good knowledge base part for general advise.
Also I changed over to the stainless steel chain of WASI having the best specification on WL/BL, stays cleaner and this does not buildup under the anchor winch (costs more as the conventional stuff).
Have 60 meters chain plus 60 meters of 8mm polyester 8-multibraid line, and to prevent the sailing behind anchor I use a riding sail.
- Lazy jacks yes, main drop system don't know. I have a main drop system and it makes it easy to cover up the sail from the UV after sailing, but during sailing I prefer to have a full look at the sail without those clothes flapping around. Just use what I have now.
- Agree with the 4 mast steps, and Keith reminds me that I really should get this one of my wish list. Will also install 2 folding steps at the top of the mast, makes working up there easier, and you can enjoy the view you have up there more relaxed.
Success with making your selection, and kind regards
Harry
