VHF antenna
Forum Name: 311 / 312 / 315
URL: https://www.myhanse.com/forum_posts.asp?TID=4445
Topic: VHF antenna
Posted By: AleSail
Subject: VHF antenna
Date Posted: 05 October 2010 at 10:05
how should I install the VHF antenna on the mast top? in the mast is already present a messenger for cable.
Alessandro
Hanse 315 - Terracina (LT) Italy
Date Posted: 06 October 2010 at 07:12
Look at the foot of the mast - You should have 2 thin lines exiting from the base
On my boat I had one for the wind & one for the VHF wire. I also had one for the spinnaker uphaul
As a point when you use the line to pull the wire through tie another line on & pull that through as well so you always have a spare to pull up more cables etc
Daydream Believer
Posted By: Andrew
Date Posted: 07 October 2010 at 17:01
Hoist the wife up the mast and get her to pull it through. I couldn't get mine to do it so I mounted my antenna on the davits. work better than the original at the mast head before it stoped working
Posted By: sowa
Date Posted: 16 November 2010 at 07:31
Cari amici Hanseatici, come dice Peter,
c'è qualcuno fra di voi che abbia esperienza con un code O
su di un 312?
Ed ancora,sempre sulla stessa barca, qualcuno ha provato l'elica Kiwi Prop, potete darmi qualche indicazione?
Grazie e buon vento a tutti.
girogasto
Posted By: Blue
Date Posted: 16 November 2010 at 23:01
ciao!
io ho la Kiwi Prop da 3 anni sul mio 311 e ne sono pienamente soddisfatto.
Meccanismo semplice e di facile manutenzione.
Te la consiglio vivamente. Poi la comunicazione con il responsabile in Nuova Zelanda è eccellente, sempre pronto e disponibile.
Se hai bisogno scrivimi anche direttamente mailto:lvigneri@icea.it - lvigneri@icea.it
Ciao
Luca
Blue
