Propellor
Forum Name: 400
URL: https://www.myhanse.com/forum_posts.asp?TID=4882
Topic: Propellor
Posted By: Eva Luna
Subject: Propellor
Date Posted: 10 March 2011 at 19:51
Hello All,
I ordered my new 400 with a standard propellor, allthough I always sailed with a Gori, on a Grinde, Dynamic 37, and a Bianca 107 due to the displacement of the boats, never more than 6 tons. The Hanse 400 will probably be a little less than 10 tons with filled tanks and all gear, and I cannot believe that the 40 cm2 of the blades influence the speed of the boat. Did any of you experience the difference?
Thanks in advance...
Minus o.b. Eva Luna
------------- Minus o/b Eva Luna Hanse 400 #794
ex Dynamic37-Bianca107-Jewel-Grinde
Posted By: taduka
Date Posted: 12 March 2011 at 12:50
I suggest you go for Gori 3 blade. have used it on many boats
Shawn
Posted By: neptune
Date Posted: 14 March 2011 at 11:13
we installed a Kiwi 3 blade...
------------- Phosphorus
Hanse 400
687#
Posted By: Albatros400
Date Posted: 14 March 2011 at 13:59
18" SPW 3 blade Varioprofile.
Posted By: lukemi
Date Posted: 14 March 2011 at 16:53
I guess I'll add to the selections here. I have a Flex-o-fold 3 blade which I like. Easy to dismantel and clean and seems to work well. Your real question though is weather it is necessary. I have been told by some knowledgable sailor friends that I would get better engine performance with a fixed blade prop and the amount of drag is minimual. Since I have never had anything but a foldable prop, I really can't verify this. I think the selection may be your use of the boat. If it is for cuising, I would do a fixed prop. If you plan to race, I believe everyone would say go with one of the better folding props for the extra 0.1 Knot speed advantage.
Posted By: Eva Luna
Date Posted: 14 March 2011 at 17:46
There is a similar 400 in our harbour, I'll check his propellor. Hope it's a foulding one. As soon as possible we'll compare the behavior of the boats.
Then I will report to you all.
Thanks for the support so far!
Minus o/b Eva Luna
Posted By: coriolis2
Date Posted: 14 March 2011 at 18:45
Minus, Bodo (the other 400) has a 3 blad flex.
Best regards, Rob
------------- "Coriolis" H350 #045 (ex Waarschip 570 #? 1987/1992, ex Waarschip 28LD #7 1994/2007)
Date Posted: 14 March 2011 at 18:48
O, forgot the mention, Bodo's 400 has the old keel and the standard North cloths called sails.
Very curious how your boat will perform with the T-keel and you also have better quality sails??
Rob
Posted By: Finn-355
Date Posted: 14 March 2011 at 22:12
If you are in doubt if a folding propellor has advantages I suggest that you read the test from the yachting monthly via below link. It is very interesting.
Finn
http://www.flexofold.com/upload_dir/docs/Test_YachtingMonthly_low.pdf
------------- Finn
S/Y EOS
Hanse 355 #038, March 2011
Copenhagen, Denmark
Posted By: petdro
Date Posted: 15 March 2011 at 11:15
@eva luna
I have a Flexofold 3 Blade 17-14 3L ,its fantastic 7,9kn 2600 1/min
Hanse Standardpropellor is: 17-12-3L
------------- Best regards
Salute H405#556
Posted By: Eva Luna
Date Posted: 15 March 2011 at 17:09
Coriolis, I have the standard North Sails, just cause I thought that North only makes quality sails, you seem to doubt that. I ordered a Elvstrom Gennaker though, with a flat cut, I am no square meter freak, but rather a trimmer. This gennaker is 24 m2 smaller, but a good reaching sail.
Thanks Lukemi, the diffrence of 0.1 knot will be a reason not to buy a foldable prop.
Finn, this is usefull!!
Regards, Minus o/b Eva Luna
Posted By: silversailor
Date Posted: 16 March 2011 at 01:16
You just cannot beat the performance, price and service of Kiwi Propellors, the best feathering prop choice for Hanse. I've had one on my 370 since 2006 and love it!
------------- Silversailor South Haven, MI USA S/V Legacy 2010 Andrews 28
Posted By: Annalethia
Date Posted: 19 March 2011 at 10:32
Bruntons auto-prop three bladed feathering. Fitted on CoCo 2 years ago brilliant. No prop walk, great stopping power and reduced fuel consumption.
------------- CoCo Hanse 400 #470
Medway UK
Date Posted: 21 March 2011 at 12:21
I've had both the Auto Prop and the Kiwi. The Kiwi performs every bit as good as the Auto Prop for 1/3 of the price.
Posted By: spilroC
Date Posted: 21 March 2011 at 12:47
Have the Gori 2 gear propeller on my Hanse 400/2008. It has some advantages to change the gear and do same speed at lower rpms say cruising at 7,7-7,8 at 2300 in. Top speed around 8,2-8,3 approx the same with either low gear 3500 rps or high gear 2700 rpms.
Disadvantage is moneuvers in the port, where you cannot judge whether in low or high gear, and u could feel lack of power if the blades are switched to high.
Today believe I would go for a flexofold 3 blades to avoid above problem - which speed you make with a flexofold pls?
Posted By: alidal
Date Posted: 11 May 2011 at 05:34
silversailor wrote:
Kiwi Propellors, the best feathering prop choice for Hanse. |
Is there any prop walk with Kiwi propellers?
------------- Hanse 400#655
Posted By: Andis
Date Posted: 12 May 2011 at 17:48
Must agree with Silversailor on his views on the Kiwi prop.
I've used it for 3 seasons and it works great. Very little resistance under sail, good speed when motoring (maybe a perfekt folding prop would get you 0.2 knots or so more, due to the shape of the blades), excellent stopping power and no prop walk. And for a great price  !
Andreas.
------------- S/Y Anne-Ma, Hanse 370 2007
Posted By: T&HB
Date Posted: 09 June 2011 at 13:24
We installed a Kiwi prop and have been very satisfied
T&H
------------- T&H
Posted By: Gran Onada
Date Posted: 13 June 2011 at 20:08
We do also have a kiwi. big difference with standard from the yard.
------------- Gran Onada IV - Hanse 350 #130
Posted By: Brufan
Date Posted: 14 June 2011 at 16:07
Gran Onada,
What size is your Kiwi Prop on your H350 ?
Do you have the standard or the 30 HP engine ?
Regards.
------------- Bruno
hanse 355 - 57
S/Y Spicy Ginger
Date Posted: 17 June 2011 at 07:49
Hi Brufan,
My engine is the 3YM30 and the propeller is a Kiwi 17" at 22º.
Posted By: kirskip
Date Posted: 02 July 2011 at 09:29
hallo!
I have a yanmar 40cv and my propeller is a flexofold 3 blade assembled in site. attention because as for as the engine warranty is only valid for propellers recommended by the motor factory. or is it not?
mauro
Posted By: panos
Date Posted: 04 July 2011 at 22:38
A young lady complains to the car dealer that her car engine broke down: "and you must know that I am a vey careful and conservative driver - imagine I never switched to 2nd gear in my life".
IMHO if an engine fails because of overloading - either by a wrong propeler or by pushing the engine too much or by letting the boat to be full of barnacles this shows and the engine manufacture will refuse to repair under warranty.
------------- Panos
Hanse 630e - selling her -
Posted By: kirskip
Date Posted: 05 July 2011 at 09:55
I probably haven't be able to properly explain my opinion. I think that the engine (sail drive) could be no more under warranty if you install propellers that are different from what is recommended by the engine factory. Sometimes it happens even if you use any gaskets different from the recommended ones.
Posted By: panos
Date Posted: 05 July 2011 at 21:48
And what I mean is that if you overload the engine, no matter how, the warrantee is of no use. On the contrary, if you install a big propeller but use it wisely and the engine fails- not from overloading but from other fault- the engine will be repaired under warrantee.
This is of course only my personal experience.
------------- Panos
Posted By: Sailingjack
Date Posted: 13 September 2011 at 18:49
Hello everyone,
Here is a new Hanse 400 owner signing in. We sailed the boat from Greifswald in July. A great boat, so far everything works fine.
I ordered her with the standard propeller but I'm planning to upgrade to a folding/feathering this winter. Options are many, finding the right mark and size might be challenging and some screws have degrees, an angle of attack of the blade, instead of pitch.
Now she gains 6.7 to 7 knots with 2400 revs (Volvo D2-40 and S130). I quess she could do better with a bit more pitch, what do you think ?
------------- Hanse 400#803 s/y Saara
Posted By: alidal
Date Posted: 22 February 2012 at 13:05
I have the standard 2-blade fixed prop. It has plenty propwalk and when I put her in astern it takes a loooong time before anything happens.... Did anyone of you changed from fixed 2 blade to kiwi or flex-o-fold, and what is your experience?
Posted By: AnnSea
Date Posted: 23 February 2012 at 22:05
I have the 2 blade flex-o-fold on my 370e, and it takes a long time to start going in reverse.
I feel it is slightly under pitched, as my engine revs out to 3600-3700 rpm. Having a higher pitch might possibly help in reverse although I wouldn't count on it.
If I had the choice I'd be trying a three blade prop.
------------- Tim
AnnSea 370e #418
Date Posted: 24 February 2012 at 07:35
With the greatest of respect to forum members so please do not take offence
Nobody seems to have answered Eva Luna's question
As I understand it what he/she seems to want to know is- has any one gone from a fixed to a folding prop & if so what was the speed difference. Not what prop each of you have or what you would guess would be the speed difference!!!
My experience of .4-.5 knots at 5+ knots is on a 311 using a 2 blade Brunton auto prop & an extra .3-.5 litres per hour fuel used by the autoprop over the volvo fixed plus poorer motoring performance with the autoprop & finally poorer manouverability in the marina
I cannot afford a 40 so sorry Eva Luna - Cannot help
Posted By: Mary 400e
Date Posted: 29 February 2012 at 19:07
Hi In below link is a "old" messages/communication about propellor on a Hanse 400. http://www.myhanse.com/forum_posts.asp?TID=3227&title=flexofold-versus-kiwi-folding-prop" rel="nofollow - http://www.myhanse.com/forum_posts.asp?TID=3227&title=flexofold-versus-kiwi-folding-prop BR Jesper
------------- Tiramisu 400e (DEN-161)
Posted By: Jacques Dubois
Date Posted: 16 March 2012 at 14:14
I disagree and firmly believe a foldable propeller results in 0,5 upto 1 knot speed difference!
------------- Jacques Dubois
Date Posted: 07 April 2012 at 19:09
So I went and bought a Kiwiprop. Last summer I had a fixed, two blade Volvo propeller; 17 x 14. With that the boat steamed 6.7 to 7 knots with 2400 revs. The new prop is a 3-blade 17 x 22 deg. I'll let you know more as soon as I manage to test it (next month?).
Posted By: alidal
Date Posted: 08 April 2012 at 06:49
Have anyone of you experienced more vibration with 2 blade flex-o-fold than fixed 2 blade?
Posted By: Idelfix Too
Date Posted: 08 April 2012 at 13:31
------------- "Idelfix too" Hanse 430e -08 Keep sailing in free wind http://suhrfa.blogspot.se
Posted By: CharlesP
Date Posted: 08 April 2012 at 13:35
That's an interesting Bulletin, but it is now over 6 years old. Has it been updated?
Charles
------------- 'MERIDIAN LADY'
320 Nr 536 2010
Medway
Posted By: alidal
Date Posted: 14 June 2012 at 18:48
Then I have replaced the 2.blade fixed 17 x 14 with 2-blade Flexofold 17 x 14 There is less vibration and the speed has encreased. I have the same speed with 200 - 300 less rpm.
Posted By: kweetje
Date Posted: 05 July 2012 at 17:40
we have replaced with a maxprop feathering one. In my opinion speed difference is between0.5 and 1 knot. I know some test reports specify litle difference, but to our experience the difference is really inetresting. With the feathering prop i got an impressive backwards power, better than with the fixed prop.
------------- First 4000 miles, no substantial problems
Posted By: Rambler
Date Posted: 26 July 2012 at 02:41
Yanmar says that you should keep the transmission in neutral when sailing. But since it was noisy listening to the prop spin, I always put it into reverse to stop the prop from spinning. Yanmar says that putting the shift in reverse could cause excessive wear of the cone clutch. I didn't want to spend the money for a new prop, but wearing out a clutch or two over the life of the boat was less appealing.
After a lot of research, I went with the Flexofold 17-13-3L 3 bladed prop recommended by the factory. After three months of use, I am very happy with the decision. The boat has the 40 hp Yanmar with the SD50 saildrive.
Full throttle is 3000 RPM's with a speed of 9 knots and about 7.5 knots at 2400 RPM. The boat also has a lot more thrust when it is first put in gear, forward or reverse. It is hard to gauge any improvement under sail but it can't hurt especially at higher speeds since drag increases by velocity squared. And it is quiet under sail with no clutch wear.
Ed
------------- Rhode Island, USA
Hanse 400, #456
Posted By: skybet
Date Posted: 13 August 2012 at 21:25
Even though it's an old post it's still very hot so I'll add my experience:
I have a Variprofile 3 blade, and it performs really well, even though it's hard to make comparison as every single boat is different... Anyhow I've tried it in rough seas and winds and I was never disappointed!
I'm a bit curious anyhow on top motor-performance of your 400's... At cruising range (2200-2300 rpm) with the volvo engine I'm doing some 6.3 knots.... I've heard here 7.9 knots at 2600?!?!?!?!?!?!? What a dream!!!!
Date Posted: 17 August 2012 at 09:52
First season with my new Kiwiprop. It feels great, stops and manoeuvres the boat much better than the original 2-blade fixed prop. Also gained 0.2 knots steaming speed. Maybe sailing speed as well... My log exaggerated 0.7 knots (10%)! I needed to calibrate it with GPS, so this may be a reason for varying speed measures on this forum.
We now get 6.9 knots SOG @ 2400 rpm.
Posted By: Rambler
Date Posted: 21 August 2012 at 00:00
Check out this website:
http://www.psychosnail.com/BoatSpeedCalculator.aspx
The 400 has a static waterline length of 35.4 feet which will yield a displacement hull speed of 8 knots. But is the waterline length increasing as the boat is under way? It sure looks like it when you look at the stern. This website also has a correction for displacement/length ratio. I believe the DL ratio for the 400 is about 220 which yields a hull speed of over 9 knots.
If you believe these formulas, why are we going so slow?
Hanse 400, #456
Posted By: alanvkrasno
Date Posted: 22 November 2012 at 12:39
On the subject of Propellers. I have a 3 blade Kiwi prop on a Hanse 400 and my best motoring ahead speed in flat water is 6.5 kn this seems slow according to recent reports from members. Astern or sailing its great. There has been wear seen where the blades hit the boss and its suggested I replace the blades. I am in a quandary about doing the work (as its only been installed 3 years) or going for a more durable Flexofold 3 blade prop. Any members have a view or should I just get the blades replaced this season. What pitch have other 400e owners had the Kiwi set to?
Posted By: bozzello
Date Posted: 26 November 2012 at 13:56
Three year ago, I changed on my H370e my factory standard three blades flex-o-fold folding propeller with a three blades kiwi prop. (Yanmar 40HP engine, on SD50) I could’nt verify the engine speed ahead comparised to that with the previous prop, but my feeling is that the new propeller give the best performance on reverse. If somebody wants to change his fixed blades propeller with my flex-o-fold, I can sell it. Diego ( mailto:diegoro@tiscali.it" rel="nofollow - diegoro@tiscali.it )
------------- Diego
Date Posted: 26 November 2012 at 14:03
I just wonder why you felt you wanted to change from the flexofold to the kiwi prop. I have decided to keep the kiwi at least for another year. I will let you know how I get on as it is having new blades fired.
Thank. Alan
Posted By: kiwihanse
Date Posted: 27 November 2012 at 05:09
Hi, I have a 2007 400e with a 40 hp yanmar and a standard 2 blade folding prop. I can get 6 knts @ 2000 rpm and 8knts @ 3000 rpm. Is there someone in the forum with a similar boat with a three blade Gori prop as the local dealer is adamant that is the way to go. Your thoughts and opinions would be appreciated. Cheeers kiwihanse
------------- kiwihanse 400e Any two yachts heading in the same direction, then it's a race!
Posted By: davidef
Date Posted: 10 December 2012 at 06:11
2600 rpm maximun rpm or cruising speed ???? The max rpm of engine are 3000 rpm, if you have 2600 m max your propeller is not correct and the engine is in over load.Please inform me the cruising and maximun speed including hthe rpm , because i want chage the prop wth flex. And i want verify the proposal of factory
Thank you
Posted By: alettaenmarcel
Date Posted: 10 December 2012 at 14:31
I think you will need a 18 x 13 inch propellor (two blade folding), I have it as well on my 370 with 39 HP Yanmar and it runns about 8,2 knots at 3000 rpm = max power
greetings Marcel
Posted By: bozzello
Date Posted: 01 February 2013 at 13:18
Because of other boat expenses (I changed my whole old battery package at the end of 2012 year) I decided to sell my H370 factory standard three blades flex-o-fold folding propeller, four seasons used, in excellent conditions, with a new anode. My request is EUR 800 (USD 1080 about), delivery costs included. Send a message to mailto:diegoro@tiscali.it" rel="nofollow - diegoro@tiscali.it
------------- Diego
Posted By: StephenDadour
Date Posted: 04 February 2013 at 05:22
Hi, I have a 2 blade folding and when we feather it it makes a huge difference to the drag on the boat.
