411 Owners Information
Forum Name: 411
URL: https://www.myhanse.com/forum_posts.asp?TID=5078
Topic: 411 Owners Information
Posted By: Sealegs
Subject: 411 Owners Information
Date Posted: 04 May 2011 at 20:02
I recently acquired a 411 and am very impressed with the boat, however the previous owner has meticulously filed all the documentation for the various components installed but there is no overall diagrams for wiring, water systems etc. Does such a manual exist?
Posted By: samba
Date Posted: 04 May 2011 at 21:24
Hello Sealegs,
I haven't found any diagrams but I have done a lot of work on our wiring for our atlantic crossing. Let me know if you have any specific questions. I will see if I can still remember it
Michiel
Posted By: Sealegs
Date Posted: 05 May 2011 at 07:50
Hello Michiel
When I switch off the batteries to leave the boat the voltmeter is still active. Are any other components still active?
Posted By: samba
Date Posted: 05 May 2011 at 08:49
Hello Sealegs,
I didn't know that the voltmeter stays active but I can understand why.
When you switch off the main switch nothing 12V should works expect for all directly connected equipment. In my case one light is active so that when I enter the boat I can switch on one light. Also my Victron battery monitor still works.
When connected to shore power all the 220V is still active. So when I leave the boat I also switch off the hotwater boiler.
Michiel
Posted By: Peter-Blake
Date Posted: 05 May 2011 at 10:05
Usually also the heating is directly connected, as the heater always needs power for the vent to cool down.
And many radios are connected directly to prevent loss of information.
The fuel and the watertankgauge are still active................
Blake 370
Posted By: Wild
Date Posted: 05 May 2011 at 20:05
He Sealegs
Normaly the bilgepump will still be under power when the battery is switch off.
If you try hard, you can get a complete wiring drawning by the Hanse Yard our your dealer by e-mail.
I have one for our boat.
Wild and Wet
Belgium
545e#268
Date Posted: 06 May 2011 at 07:40
@wild:
Thats what i thought too when i bought my hanse in 2008. To my surprise the bilgepump was out of order when the main switch is off! I wanted it to be changed by the yard, but i was told that this is standart on hanses......
Blake 370
Posted By: Wild
Date Posted: 06 May 2011 at 10:55
@Peter
Maybe thanks to you the change this.Can you try to do this also for a lot of other thingsWink
Wild and Wet
Belgium
545e#268
Posted By: Sealegs
Date Posted: 06 May 2011 at 14:13
Thanks guys for your responses. I'll do some more checking when next at the boat...
