An extra fresh water tank
Forum Name: 411
URL: https://www.myhanse.com/forum_posts.asp?TID=5630
Topic: An extra fresh water tank
Posted By: Jøvani
Subject: An extra fresh water tank
Date Posted: 13 October 2011 at 20:00
Has any 411 owner installed an extra fresh water tank? In case does it exist an original tank to purchase? Where is it mounted and how is it connected to the pipe system? I have a bow truster mounted in front of the standard freshwater tank, so no free room there. Would appriciate any good advices. Smile
Jøvani
Jøvani Hanse 411 #189
Tønsberg
Norway
Posted By: Chris G
Date Posted: 14 October 2011 at 11:20
Hi Jovani,
I looked at this and ended up fitting a watermaker, however fitting a custom made tank in the space under the port aft outboard of the fuel tank would allow you to almost double your capacity.
Chris G
H411 "Equinox"
Posted By: Jøvani
Date Posted: 14 October 2011 at 21:36
Hi Chris G,
Thanks for your response and advice. Interesting that you selected a water maker, do you mind telling me how you came to that conclusion? May I aslo ask what make did you select, which capacity and how did you integrate it into you fresh water sytem?
Tønsberg
Norway
