Our purchase of Freya has exceeded our expectations. She is fast, exceedingly comfortable and stunning to the eye. After 4 months of ownership we have drawn up following observations to make her even better:
1.Two mast steps about two feet from deck level at the mast so the main halyard can be attached without risking life and limb,
2.Always take the topping lift forward as it has a habit of fouling in the backstay turning block eight feet above the steering position, usually at the worst possible time,
3.A flap of canvas over the long zip over the boom cover to protect in from our fierce Aussie sun
4.Rails in stern lockers to stop ropes/fenders disappearing into the abyss,
5.as the mainsail batten pockets can foul the backstay in light winds during tacking, Norths have adjusted the pocket ends to allow clearance,
6.does anyone know exact tankage specs? Fuel seems to be 90 litres and water 200 litres?,
7.the retaining device on stern ladder, while clever, is dangerous especially for children,
8.two more turning blocks added to mast base as no cunningham possible if two spinnaker halyards are carried,
9.the spinnaker halyard collar device at the hounds looks overly abrasive
10. why twin headfoil as standard but only one genoa sheave in mast ????? New owners beware!
11.anchor locker is close to bow making it hard to carry anchor on the bow unless the shank is very short. A 35lb manson from New Zealand fits nicely with minimal alteration to the anchor locker hatch.
12.Mysterious water leak to bilge reported by two boats not yet solved,
13.Fridge basket is too big to remove once full , a shorter basket would be better.
14.Electrics could do with a restraining arm to limit fall on openning.
15.North sails are overly deep but local Norths readily make adjustments
16. We have strengthened boom cover lazy jack attachment points which are flimsy especially at the forward end.
17.Watch for first reef block which can be damaged if halyard lowered too far as the block abrases the boom as pressure is wound on.
18.Lazy jacks need cleats on the mast each side to allow securing (new Spinlock PX 0308/1 cleat is excellent.
19.Standard battery instrument guage is too small and imprecise. There is some excellent technology available which should be standard.
20.The gas locker is too small (especially after silly Aussie fittings are attached to the lines in place of the excellent German ones!)
21. The fridge is below expectations and seems to have insulation issues.
22.An angled shelf high in the anchor locker to take a windlass is a winner but get the angles right. Don't forget a drain hole.
23.Spinnaker kit ex factory excluded winches.
Happy sailing! The list of positives is much longer than the above.
