Bow Ladder
Forum Name: 311 / 312 / 315
URL: https://www.myhanse.com/forum_posts.asp?TID=6415
Topic: Bow Ladder
Posted By: PRCH
Subject: Bow Ladder
Date Posted: 19 March 2012 at 20:49
Hi all
Has any of you found a suitable bow ladder for our Hanse 311/312/315?
Peter
Posted By: JanH
Date Posted: 21 March 2012 at 12:26
Hi Peter,
I have a ladder from Båtsystem on my 312 that works fine, not sure if it´s a ST125 or ST130. I don´t have a bow spring.
www.batsystem.se
Jan
Janne
Hanse 312
Posted By: Forth
Date Posted: 07 April 2012 at 13:27
I use this ladder.
Its done for the 10 Kg delta anchor assembly.
It works well and fits into the anchor locker.
/Mike
Posted By: danro1968
Date Posted: 11 April 2012 at 12:08
We have installed a bow platform with bow ladder from Batsystem.
There are two advantages :
- the anker is not so close anymore to the front of the boat
- you can mount easy and quick the bow ladder that goes with the platform
Realy good solution.
Posted By: Kox
Date Posted: 01 April 2022 at 10:55
Originally posted by Forth Forth wrote:
I use this ladder.
/Mike
I realize this is an old thread, but does anyboby know the make of the bow ladder posted by Forth?
Anybody has it? Comments?
Other solutions that are working well for you?
Hanse 315, Ella, Hull# 640
Date Posted: 01 April 2022 at 11:06
I have this ladder made, it slides over the stainless steel plate.
Date Posted: 01 April 2022 at 23:27
Quote I realize this is an old thread, but does anyboby know the make of the bow ladder posted by Forth?
Hi kox
Please add your country to your profile or signature.
Try google "bowladder Bruce" and view the pictures, you will see similar ladders. I get results from Niro Petersen in Flensburg Germany.
If you are in the EU you could buy from
https://www.niro-petersen.de/en/shop/anchors/bow-ladder.html" rel="nofollow - https://www.niro-petersen.de/en/shop/anchors/bow-ladder.html
But if you copy the design and pay a Welder you can get a ladder made anywhere....
Hanse 370#487 30HP 3-cabin
Posted By: Kox
Date Posted: 03 April 2022 at 17:27
That's a very nice solution.
Your boat doesn't look like a 31x though, it looks a lot sturdier than mine. The side of the anchor-holder is too weak for your solution.
Posted By: Kox
Date Posted: 03 April 2022 at 17:34
Hi kox
H8jer, I'm just around the corner from you - in Lynæs :-) And now my profile is updated. Thanks.
I have looked at Niro Petersens homepage, but I couldn't find the solution shown by Forth. I have written them a mail. It sure looks like Niro Petersen.
Date Posted: 03 April 2022 at 17:37
You are right, the boat is a H345 from 213.
As far as I know Hanse uses the same bow arrangement on several models.
The side is stainless steel ç(4?)mm. Even with 120 kg loadUnhappy it flexes minimal
Posted By: Lars100
Date Posted: 06 June 2025 at 12:27
Dear Fendt, do you have drawings for this very nice model??
