301 .light wind performance
Forum Name: 300 / 301
URL: https://www.myhanse.com/forum_posts.asp?TID=6431
Topic: 301 .light wind performance
Posted By: Ebrill calandra
Subject: 301 .light wind performance
Date Posted: 24 March 2012 at 08:42
I am thinking of buying a 301 as I have read favourable reports on this site.
However I am concerned as to the light weather performance and am wondering
If fitting a sail rig from a 415 would improve it.
Has anyone done this ? And could you give me any tips as to how to do it
Posted By: Peter-Blake
Date Posted: 24 March 2012 at 09:29
Why not adding the rig of the 630? Would improvbe much more the light wind performance LOL
Blake 370
Posted By: Windsurfer
Date Posted: 24 March 2012 at 15:46
There's still 6 days before the 1st April jokes....Wink
Hanse 320 #079
Posted By: kirkelund
Date Posted: 24 March 2012 at 18:47
Yes, I was checking my calender as wellLOL
Ole,
Kirkelund
"Amani"
Lynetten, Copenhagen, Denmark
Hanse 342 (grey hull, wheel steering, deep draft keel, Jefa rudder - RUD34)
Posted By: Henrik84
Date Posted: 24 March 2012 at 23:21
I checked the calander too.
I would say that fit a mast from 415 to a 301 is a joke.
You canīt take all that weight on a 301, you would tip over in light winds.
You cant even have a mast from 320.
S/Y LaRey
Hanse 320 #430
Gothenburg, Sweden
Posted By: Juno
Date Posted: 26 March 2012 at 08:11
I had thought that I could fit an outrigger to improve stability, but that would make marina costs prohibitive
And going everywhere on a port tack difficult.
My latest plan is to fit a 125 hp engine that would gives entry of ballast in the right place
I also calculate that it should give me a cruising speed under power of 32 knots
This would mean that I could make a passage from Barmouth to Dublin in 3 hours saling or motoring
This would give me lots of Guinness dr,nuking time.
Posted By: kiwihanse
Date Posted: 26 March 2012 at 09:30
Yeah, If you look around there is possibly a keel off one of the old america's cup boats that you glue on the bottom, good luck!
kiwihanse 400e Any two yachts heading in the same direction, then it's a race!
Posted By: holby
Date Posted: 26 March 2012 at 09:42
Juno, perhaps you could tow me from my mooring in Barmouth......Wink
Date Posted: 26 March 2012 at 10:06
The first scetches are done:
before relaunch
after relaunch
BTW. I also inflated the hull  a little bit. this way the 301 has much more space inside, but you only have to pay for the size of a Hanse 301 as you pay by length in most harbours....Wink
Blake 370
Date Posted: 26 March 2012 at 10:53
As far as I know the 301 is the only Hanse with a wing keel so with a few more horsepowers you could fly across the Irish Sea. Good luck!
Date Posted: 26 March 2012 at 12:05
I am suprised Holby has not told you how superfast a 301 is anyway, without turbo charging.
He does not normally miss a chance to extol the virtues of the 301l !!!
He must be slacking!!!
Posted By: holby
Date Posted: 26 March 2012 at 12:28
Samuel, I have been asleep and missed this chance.......... but yes you are so right it is a superfast Hanse, blah, blah, blah, zzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzz!!!!!!!!
Date Posted: 27 March 2012 at 10:34
Hows everyones knowledge of the Welsh language ?
Posted By: Andrew
Date Posted: 27 March 2012 at 11:56
With some of the epoxy left over from any repairs you could extend the water line length to that of a 415 while your at it, but then you open your self up for higher marina cost.
Andrew
Date Posted: 27 March 2012 at 12:45
I extended the waterline without extending the boat itself:Wink
Now it looks like a 2012 modelEmbarrassed
Blake 370
Posted By: trist33
Date Posted: 27 March 2012 at 19:15
Nos da!
"Discovery" Hanse 320
Brixham, UK
