wiring diagram 470
Forum Name: 461 / 470
URL: https://www.myhanse.com/forum_posts.asp?TID=6901
Topic: wiring diagram 470
Posted By: takomitak
Subject: wiring diagram 470
Date Posted: 31 August 2012 at 10:21
there anyone can send me the wiring diagram for the 470?
Many thanks
Posted By: Blueskies
Date Posted: 04 September 2012 at 17:37
Yes, I have the complete wiring diagram for the 470/540(545) passed to me from a forum member.
If you give me your email adress I can send it to you.I will send your mine under private messenger. It's quicker this way.
'Caroline'
Hanse 470#306
Posted By: sequale
Date Posted: 25 February 2013 at 22:13
can you also sent me the wiring diagram
Posted By: Andreu Mateu
Date Posted: 18 May 2013 at 06:30
i also would like to receive the wiring diagram. thanks
Andreu Mateu
Barcelona, Spain
Owner of a Hanse 470e named "Kontrakorriente"
amateu@dreamsandadventures.com
www.kontrakorriente.weebly.com
Posted By: DBQP
Date Posted: 23 April 2014 at 20:35
Hi, I have just bought a 2011 545 - the wiring diagram would be such a help to me - my anchor wash pump doesn't work & I have no idea where to start. Many thanks.
Posted By: tobo2
Date Posted: 03 May 2014 at 16:49
Why not putting this diagram on this forum so that every 470 owner can download it??
Posted By: Wild
Date Posted: 23 May 2014 at 10:30
Hello Tobo and DBQP
I have the complete wiring diagram for 470-545 but can not find a way to put it on the forum(wrong size)
If you give me your email adresse I will send it to both of you ASAP.Can take a few days we are on the sea right now.
So far I can see the deckwashpump have only the aut breaker(10Amp) switch on the Phillipi panel and go by a connection in the Forward BB head (there where the showerpump and in case the elect toilet are connected)
Wild
Info@wildandwet.be                                                    [
Wild and Wet
Belgium
545e#268
Posted By: Lainoa
Date Posted: 23 May 2014 at 16:50
Hello Hanse fellows
Sorry for being my first message into this usefull forum .I am the ownwer of a 545 and I am interested in the wiring diagram too
Joseba
Hanse 545 lainoa (unit.306)
Posted By: trimix
Date Posted: 23 May 2014 at 23:22
Joseba
Please call me and i Will send you the documents
Kostas
Posted By: dfcatanz
Date Posted: 06 August 2014 at 20:34
I know you have received many requests for this valuable document.  I too would very much appreciate your sending me a copy as well!
Best regards,
Dan Catanzaro
dfcatanz@gmail.com
Posted By: Anto
Date Posted: 21 August 2014 at 10:26
Hi, I have just bought a 2007 470- the wiring diagram would be a big help to me
Many thanks
Best regards
Antonio
H470#138
Posted By: NIRVANA III
Date Posted: 08 December 2014 at 19:53
Can you also send me the wiring diagram
martin@cohimar.com
Thank you
Posted By: Anto
Date Posted: 09 December 2014 at 01:00
Hello
I have send you directly to your email the wiring diagram
If you are prepare your boat to cross the Atlantic please share with us your works.
I won't do that next year
If you came to Portugal call
Best regards
Best regards
Antonio
H470#138
Posted By: Anto
Date Posted: 09 December 2014 at 01:09
Martin
This diagram was send me by David Parker from Myhanse forum
Anton
Best regards
Antonio
H470#138
Posted By: Wilkie
Date Posted: 10 December 2014 at 07:00
Really sorry to ask as well but I would love a copy of the wiring diagram! wilkie@outlook.com
I must admit I was amazed one wasn't supplied with the boat.
Thank you very much in advance.
Posted By: jeancharleb
Date Posted: 15 December 2014 at 03:45
I have the plan of the 470e 2010
jeancharleb1@gmail.com
is my address
Jean Charlebois
Posted By: lbb
Date Posted: 03 November 2015 at 07:20
Hello friends.
Will one of you please send the wiring diagram to my email
 lbbaadsgaard@gmail.com
Thanks in advance and hope to get helpfull in some other issue
lbb
lbb
Posted By: SausalitoDave
Date Posted: 04 November 2015 at 05:20
I just posted the 505 wiring diagram to the manuals section.  It may be useful.
Hanse 505
Festina Lente
Posted By: Hanse 540
Date Posted: 19 October 2016 at 21:41
Can i please also trouble you for the wiring diagram would like to instal a generator and would like to know where the wiring in this yacht goes thanks peter
peter_davis100@yahoo.co.uk
thanks in advance
Posted By: Wild
Date Posted: 20 October 2016 at 08:36
Hello Peter
I have sent you the wiring diagram for Hanse 470-545 2010 by email.
I am not shure it will fit complete for the older 470 but in great lines it will be the same design.
Wild
Wild and Wet
Belgium
545e#268
Posted By: Wild
Date Posted: 20 October 2016 at 11:22
Peter,
please have a good look on the wiring diagram I have sent you
On page 7 (battery banks) there is no battery combiner ,the engine-generator starter battery is fully separated from the service batteries.
To charge the engine-generator starter battery they use the separate outlet(+12V)on the Victron Multiplus charger-inverter (page 2) who is limited to 4 A and with a slightly lower voltage output.
I did the installation of the generator myself exactly like on this diagram, connecting the + 12V for the generator on the engine battery swith (page 7)and the - 12V on the negative busbar (page8) it works fine for 6 years.
Wild and Wet
Belgium
545e#268
Date Posted: 21 October 2016 at 00:59
If it is any help, I put the 505 wiring diagram up in the manuals section about a year back.  It is probably very close.  Just checked, it is still there.
Festina Lente
Sausalito, CA
Date Posted: 31 October 2016 at 16:54
if someone knows how to publish on 470 site the wiring diagram I will send it to him or her.
Jean Charlebois
Posted By: Wild
Date Posted: 01 November 2016 at 16:29
uploads/2431/elect_schema_HANSE_545.pdf" rel="nofollow - uploads/2431/elect_schema_HANSE_545.pdf
I hope this will work
This is the elect wiring diagram for Hanse 545-470 2010
I will try to put it on" manuals and drawnings"
Wild and Wet
Belgium
545e#268
Posted By: Manifk
Date Posted: 03 November 2016 at 12:09
Many thanks
Hello Takomitak,
i am uploading them
uploads/4803/8.6.2_H470Beleuchtung.pdf" rel="nofollow - uploads/4803/8.6.2_H470Beleuchtung.pdf
Manifk
Posted By: Manifk
Date Posted: 03 November 2016 at 12:26
If any one wants the originals send me your emails and i will send them to you as attachments
cheers
Posted By: Goran
Date Posted: 08 March 2017 at 18:34
I would appreciate if you could send me a wireing diagram for our Hanse 470 or kindly indicate where i can get.
My e-mail address is goran.heintz@ergobepharma.se
Best regards
Göran Heintz
Posted By: tobo2
Date Posted: 12 March 2017 at 13:21
After a long search I finally found it again, and you can download it from my server:
www.sarabella.ch/downloads/wiring_diagram-H470-H545.pdf  .Without garanty and it is a version of 2009!
Date Posted: 22 March 2017 at 02:52
1st check if there is current
Jean Charlebois
Posted By: jenspl
Date Posted: 06 April 2017 at 08:21
Sorry, but I too would really appreciate if you could send me the diagram!
my address:
jens@plotner.com
many thanks in advance!
jens
Posted By: Manifk
Date Posted: 18 April 2017 at 19:16
Jens
i sent you all the wiring diagrams by email.
regards
Malcolm
Posted By: Chris_S
Date Posted: 12 June 2019 at 15:27
Hello,
Can anyone send me the electrical diagram of a 2010 Hanse 470?
public@aeromarine.com.uy
Thanks and best regards,
Chris
Chris
Posted By: Wild
Date Posted: 14 June 2019 at 19:19
hey Chris
I have sent you by mail the wiring diagram for the 545 and 470/2010
There are the same only on a few small things they have difference but thats indicated.
Wil
Wild and Wet
Belgium
545e#268
Posted By: TurnbullJ22
Date Posted: 20 August 2019 at 07:44
Hi, I've got a 2008 470e with the MaxPower bow thruster and the 75 HP engine. Does anyone have a wiring diagram for this model? Trying to find out where the green/blue wire that closes the 70A relay on the back of the panel gets it's power as not closing the relay?
Posted By: Sandy
Date Posted: 23 September 2019 at 01:10
yes great idea - I need all the information on the 470e I can get. My boat came with zip info!
Posted By: jeff
Date Posted: 21 January 2020 at 05:02
Hi , can anyone send me the electrical diagram for th 470 from 2010.
I need to change all electronics navigation system and install a battery controller .
Posted By: Sandy
Date Posted: 22 January 2020 at 09:20
Posted By: FORELA
Date Posted: 22 January 2020 at 22:35
Hello Blueskies, do you still have a copy .pdf of the wiring diagrams for the 470?. i just bought a pre-owened 2009 and I am trying to have as much documentation as possible in order to learn all details of it.
Thanking you in advance,
FORELA
Posted By: Wild
Date Posted: 23 January 2020 at 08:51
hello Forela
I have put this diagram 01/11/2016 on this forum.
Look under “Manuels and drawnings”
Topic “545-470 2010 elect wiring diagram”
In the 2010 Hanse there are only small difference  between 545 and 470.
Wild and Wet
Belgium
545e#268
Posted By: jeff
Date Posted: 23 January 2020 at 15:24
Thanks Wild
Posted By: Fede Cavallo
Date Posted: 10 June 2020 at 14:54
Hello, I´m trying to put an anchor control near the tiler but I need to find the wiring. Could I pleas have the electrical diagram as well. Thank you very much.
Posted By: jeff
Date Posted: 10 June 2020 at 17:58
please see attached file  uploads/6112/plan_électrique_470.pdf" rel="nofollow - uploads/6112/plan_électrique_470.pdf
Posted By: Mark Johnston
Date Posted: 29 October 2020 at 23:52
wiring diagram schematics please if you don’t mind- have been chasing one since last year.
argoodwin01@gmail.com (aka wifey)
HugStarBig smile
Date Posted: 29 October 2020 at 23:53
no need I 8 found it!
Posted By: Sandy
Date Posted: 01 September 2022 at 02:15
Please send me wiring diagram
Posted By: Wild
Date Posted: 01 September 2022 at 07:49
hello
In the search function you can find this electric diagram
Search under topic” tel:545-470%202010" rel="nofollow - 545-470 2010 electric wiring diagram” any date and you will find a link to download.
Date of my post 01/11/2016
Our look a little bit back in this topic to the message by member Jeff 10/06/2020 link “uploads/6112/plan_électrique_470.pdf”
If you can’t find it give me in PM your email address.
Wild and Wet
Belgium
545e#268
Posted By: Sandy
Date Posted: 01 September 2022 at 13:03
thank you kindly Wild.
I looked back through some posts but couldn’t find reference to it again, so your email and link is very appreciated.
Fair winds to you.
