'Wet' heating system
Forum Name: 415/418
URL: https://www.myhanse.com/forum_posts.asp?TID=7047
Topic: 'Wet' heating system
Posted By: High Time
Subject: 'Wet' heating system
Date Posted: 05 November 2012 at 09:48
This is a general query, but as I have a 415 I will post it here.
I am seriously considering installing a 'wet' heating system in High Time. The Eberspacher Hydronic D5 seems to fit the bill and is (slightly) cheaper than the alternative Webasto ThermoTop C.
My questions - has anyone reading this installed or used a wet system and, if so, what tips can you offer about installation or comments would you make about operation and reliability of the system.
Thanks in advance.
Roger
High Time (415 #038)
Posted By: Wild
Date Posted: 05 November 2012 at 14:31
hello High Time
A few days a go I have put a post under 470 in Topic "461 our 471"  about such a installation.
It works very well: No noise, No dry air, individual control and the installation is not very difficult.
If you send my a pm with your email I can send you mine drawnings from the installation IYW.
Wil
Wild and Wet
Belgium
545e#268
Posted By: Jøvani
Date Posted: 05 November 2012 at 15:26
Confirm this type Eberspacher is very good, I installed the smaller type, think it is 3,5kw, 3 years ago. It functions excellent. Start every time with no problem, even after a long winter. I do not use it as the main heater, only to heat the water. It is really very convenient to have all the hot water you want even without the shore power connected or engine running
Regards Jøvani
Jøvani Hanse 411 #189
Tønsberg
Norway
Date Posted: 05 November 2012 at 19:41
Originally posted by Wild Wild wrote:
hello High Time
Wil
I've now read your post and it sounds encouraging.
I've also sent you a PM.
Roger
Date Posted: 05 November 2012 at 19:42
Regards Jøvani
Sounds good - thanks.
Roger
