lock motor shaft
Forum Name: 575/588
URL: https://www.myhanse.com/forum_posts.asp?TID=7604
Topic: lock motor shaft
Posted By: marcopone
Subject: lock motor shaft
Date Posted: 03 July 2013 at 13:11
on my new 575 I am not able to lock the motor shaft in order to have the propeller folded when sailing
the volvo D3 motor is mounting an hydraulic reverser and the normal system of putting the throttle in reverse gear position does not work
I tryed to put the reverse gear both before and after stopping the engine but it does not work
anybody is experiencing the same issue and may be found a solution ?
thanks and regards, marco
Posted By: pideas
Date Posted: 03 July 2013 at 17:34
I have on my 445 in conjunction with the SMS system also an electrical motor control (electrically by adjusting motor not hydraulic). After I put the engine shut off the engine lever to reverse position and then turn on the master switch off.
Works just fine. Hanse also could not tell me how it works at handover.
Are you sure that your system Hydraulic works?
Sailing is a Passion, ex Hanse 445, now Moody DS 54
H445#74
Date Posted: 04 July 2013 at 15:15
dear pideas,
I am not sure to understand what you mean in your message
How is the exact sequence you use on your H445 to stop the rotation of the shaft ?
you stop the engine
you engage the reverse gear
and you switch off the main motor switch ?
you have a Volvo motor ? which type ? D2 ?
Posted By: pideas
Date Posted: 04 July 2013 at 19:33
hi marcopone
exactly as you described it.
I have a Volvo D2 -75
H445#74
Date Posted: 05 July 2013 at 12:21
I will try this weekend, thanks and regards
marco
Posted By: anil1227
Date Posted: 17 July 2013 at 12:47
Hi marcopone and pideas
Interesting conversation! we just got the delivery of our new hanse 575 and we are experiencing the same problem (not able to lock the shaft)
unfortunately i did not understand how pideas locks the shaft.
qte
you stop the engine
unqte
the gear lever is electronic hence reversing the gear after shutting down the engine seems to have no effect on the engine.
regarding switching off the motor electricity, I am not sure how that is going to lock the shaft.( also could you please kindly clarify where this switch is located in the boat)
thanks in advance
Posted By: hmtkpt
Date Posted: 01 September 2013 at 21:43
So anybody who find the solution yet?
Posted By: Isatis
Date Posted: 18 December 2013 at 08:27
marco
I have the same problem ... Did you find a solution?
Date Posted: 18 December 2013 at 12:43
no solution yet, I am still dealing with the many other major problems of this boat and I postponed the solution of this point
it is very strange but I do not find much in the net, this should be a very common and well known problem with hydraulic transmission motors
I think eventually we will have to install a disc brake to lock the shaft while sailing, look at this :
http://www.bruntons-propellers.com/Autolock/Autolock_home.htm
Posted By: Curio
Date Posted: 16 February 2014 at 20:11
I had the same problem on my hanse 540 with d5 engine. First i had a volvo folding prop, then changed to a three bladed gori. Combining with Stopping the engine when driving forward, it will make the propeller adjist in such a manor that the rotation stops. Good luck
Posted By: Mark_J1
Date Posted: 06 April 2014 at 18:01
On a D3 try this..... with engine running and in-gear try simply stopping the engine using the start/stop button.  Then turn off the the ignition using the ignition button.  Then simply select the neutral position ready for restarting the engine.
