ordered!
Forum Name: 345/348
URL: https://www.myhanse.com/forum_posts.asp?TID=7790
Printed Date: 27 March 2026 at 05:01 Software Version: Web Wiz Forums 12.06 - https://www.webwizforums.com
Topic: ordered!
Posted By: richz
Subject: ordered!
Date Posted: 02 September 2013 at 22:52
Hi Everyone! I've been following you for a while. Now that I've placed the order for my H345 I decided to register and leave this message. Every advise for a new owner is more than welcome.
Richard
Date Posted: 02 September 2013 at 23:48
Richz, Welcome to the forum. Congratulations on placing your order for a 345. Looks like a good size and good performing vessel. I gather we would all like to know what options you ordered, the layout selected, why did you select a Hanse and where you intend to sail her. Do you have a name for the boat yet?
Posted By: holby
Date Posted: 03 September 2013 at 08:31
Richard, Welcome to the forum........ Lovely looking yacht... Look forward to seeing photographs when she is delivered to you... I see your location is London, where will your yacht be based? Good luck and enjoy... Dave
Posted By: richz
Date Posted: 03 September 2013 at 09:11
She will be based in Italy (Northern Adriatic Sea) and I am expecting the delivery for Spring 2014.
It's the standard layout and I've included performance, electronic, cruising and comfort pack, plus few other options. I am thinking of including also a longer anchor chain as the one offered with the pack (30mt) seems too short. thinking of 50 mt instead. what do you think?
Date Posted: 03 September 2013 at 09:21
Hello Rich,
in the med a longer anchor chain makes definitely sense. I would go for 50 m but in stainless steel for easy free fall stowing in the chain locker. You might in fact get better prices for stainless chains in Italy.
Did you check, that the authorities agree with hull length < 10.0 m in order to avoid the luxury tax?
Did you go for the comfort matresses and the side entries ?
Date Posted: 03 September 2013 at 09:40
Here is what I ordered, after a lengthy decision making process:
a) Full Simrad electronics package with WiFi ( this is really great )
b) VHF ( comes with AIS splitter ) fitted , you get an extra wireless handset with it
c) biggest engine available with folding prop ( doing 6+ knots at quiet 2000 rpm )
d) side entries
e) bow thruster ( fitted by a subssupplier ), you might not need it in the med
e) electric winches ( can you get your companion on board again with your manual winch ? )
f) Elvström FCL sails ( they are absolutely fantastic close hauled )
g) Teak in Cockpit, but not on decks it simply gets too hot in the Med
h) Cockpit cushions
i) I heard that next season they will offer an additional fridge again in the cockpit (take it, the standard 2 door fridge is not powerful enough for the med climate ! ) Not sure if this applies also to the H 345.
j) we took the gennaker package ex works.
k) the Fusion 600 entertainment package ( make sure that you have an old ipod with the 30 pin connector, so that it fits into the slot )
l) take the big inverter ( can operate a Nespresso machine )
m) the comfort mattresses
n) Eberspächer diesel heating system
My mistake was that I ordered all canvas ex Yard, the quality of the tissue is lousy , it simply does not fit. The design is plain stupid, you can not operate the additional genoa winches with the sprayhood up. The a bimini does not let you sit comfortably behind the wheel, and it does not uffer UV protection to the helmsman.
Do all canvas work locally, then they can fix any snags quickly. You can also specify the best material for UV resistance ( Sunbrella ). Specify also side shades which you can attach to the bimini. Italy is a good place for this.
In Mast Furling or Lazy jacks is a matter of personal preference. We went for FCL with batten cars and it works great.
I think that you can live without a radar in the med when you have ordered an active AIS ?
I would also think about an aircon in lieu of the diesel heater which you can switch to heating if necessary.
Remember that Hanse are great boats offering excellent value for money. Their disadvantage is that adding gear afterwards is an arduous task.
Date Posted: 03 September 2013 at 11:43
Rich, Re your anchor chain - it depends on how much you anchor rather than pick up mooring and if you anchor do you anchor overnight and obviously what depth you are anchoring in. The other consideration is what is the seabed composition. The normal acceptable ratio of water depth to anchor chain scope is 3 to 1 in good conditions. So with 30 meters of chain you could anchor in good conditions (wind and wave) in around 9 meters of water as you would have about 27 meters of chain in the water (there is still chain connected to the bitter end, on deck and above the water). If I were anchoring overnight I would look at using 5 to 1 ratio. In bad conditions you may opt for up to a ratio of 10 to 1. If you are concerned about weight - 8mm anchor chain weights about 1.4kg per meter you could use the appropriate rope rode to lengthen you anchor rode as long as your anchor winch will successful winch rope and chain combination. If you are keen on racing I guess you have the minimum of chain and make up the difference with rope. If you are cruising and not too worried about the extra weight and will be anchoring regularly the safest option is to go for all chain and the more the better. On our vessel (on order as well) we are pushing to fit in 140 meters which we will occasionally use all of it as we do now. The other consideration when talking about anchoring is the weight and design of the anchor. In various areas some anchor designs work better than others due to the seabed type. Ask local owners what works best in your chosen area. Regarding the anchor again more weight is generally better. We went from a 27 kg to a 40 kg anchor which is now the "standard" on offer for the 2014 model. Frank's list of options looks good and his suggestions for the MED make sense. Good luck with this new boat.
Posted By: richz
Date Posted: 03 September 2013 at 13:40
Hi Frank,
No comfort mattresses (mainly daily cruising) and no side entrances (not really needed in Adriatic Sea). my option list is much shorter than yours (includes teak on decks, though). I have followed your advise (spotted in other posts) and did not order the canvas from the yard.
Posted By: richz
Date Posted: 03 September 2013 at 13:42
thank you Wayne, I will go for the 50 mt then just to have a bit of flexibility...
Posted By: Silver
Date Posted: 03 September 2013 at 20:49
Hi Richard,
welcome on board, great choice - just like mine, Frank's etc
My configuration is quite similar to yours, i.e. performance (with 30 HP Volvo), electronic, cruising and comfort pack; difference : sprayhood, bimini and no teak on deck; plus, I replaced the foldable propeller with a Kiwiprop - btw I have the original Volvo untouched, if anybody is interested to get it discounted - and added Coppercoat - easier to do it on a new boat.
Oh and I got the two-cabins version.
Sofar I'm pretty happy with the boat and I'm sure I will for a long time, she sails very well and is very comfortable.
With regard to several remarks I've seen here and there, I'd like to add the following:
- yes 30 mt is not enough for the anchor chain, and I'd rather have it heavier, too; - the anchor roller is a bit too short, say 10 extra cm would reduce the risk of hitting the anchor against the bow in rough sea; - if Frank refers to Italian law, yes the boat is agreed to be below 10 m and pays no tax at all - just like every other boat till 14 m nowadays, which I don't think to be very correct given the general economic situation but I don't want to go OT. - I did not get the comfort mattresses and I admit I miss them; pity Hanse's documentation was insufficient when I ordered, for instance there was little info about this, the two-cabin version, and the bimini. - FCL sails can be trimmed easily enough even by people with little experience like me; - I got the mast steps courtesy of my dealer, they were neither included in the specs nor available as an option - but present in every leaflet! - I'm not so dissatisfied with the bimini as I mainly wanted to use it when moored, but surely it could be done better - just like the lazy jack and lazy bag; I moved the back lateral bars to sternside and now I can sit better, I'll post a picture; you can see the original layout in the 345 bimini thread. Anyway you definitely need a bimini in the Med. - I'll add an AIS only when and if I'll travel at night; also because I'm in the Ligurian Gulf, but in northern Adriatic you can find fog in autumn - wintertime so you might consider a radar. - top issue sofar: my Simrad NSS8 shuts down when I enter a route ... or when I look for harbour's pictures with the Platinum+ card. I'm waiting to hear back from the dealer on the subject, I suppose the matter will pass to the Simrad support network.
Enjoy your H345!
Maurizio
------------- Hanse 345 # 51 Performance sails Volvo D1-30 KiwiProp Coppercoat
Posted By: richz
Date Posted: 03 September 2013 at 21:36
Hi Maurizio, Thank you for your suggestions. I've included the AIS transponder, it's one of the few options I added alongside an additional multifunction display to be located at the chart table. I am curious about the mast steps you are mentioning in your post; I thought they were included as standard; are they not? Electronic supplier for 2014 model is B&G. I am definitively going to add a bimini, but still concerned about the one offered by the yard.
Ciao,
Richard
Posted By: Silver
Date Posted: 03 September 2013 at 22:19
Hi Richard,
I confirm my boat arrived w/o mast steps; my dealer said it was normal as they're not included in the specs - which is true if you look in the Hanse website. Anyway she gave me a couple for free. However, out of curiosity, I checked Hanse's docs for the 385 and 415 as well; they're not mentioned, either, but you find pictures in all cases, including the 345. A friend of mine with a one-year old 415 got them as standard.
Another minor drawback of my boat is that the control panel is not hinged, I pointed this out when I visited the yard in May. I read that Frank got the better hinged version little time later. Also B&G electronics must be probably better, same hardware, I think, with improved firmware. Anyway also the NSS8 should be very good,if only it worked as expected..
Re bimini, this week-end I'll take some more pictures to give you a better idea before you decide. For sure, your head is not protected when you're at the wheel, and the view over the sails is obviously obstructed - I keep it open only when motoring. I repeat, it's good when you're moored - at least against sun, I haven't tested it so much under rain.
Bye,
Maurizio
Posted By: richz
Date Posted: 03 September 2013 at 22:30
Hi Maurizio, give a look to this website: http://www.styleinboat.com/index.php/voilier/hanse/hanse-345/bimini-hanse-345.html# This appears to be somehow better and it should not obstruct the boom when close hauled. Thanks for the heads up about the mast steps; it's a minor thing but nice to have.
Posted By: Silver
Date Posted: 04 September 2013 at 13:11
Hi Richard,
at first sight it looks better, but you have to see how high is the boom raised by the topping lift; I can get a similar clearance, maybe less but enough, with my standard bimini if I'm not sailing. If, on the other hand, the topping lift has no effect here, it means that the bimini is somewhat lower than the factory-supplied one.
Surely the French one offers better protection to the helmsman, it would be nice if the two bimini sections could be folded independently, so to close the front one and keep the view on the mainsail, but I would not say this looking at the picture.
A minus compared to the Hanse (Rados) one : I see that the main supports are mounted on the side dekcks, while Rados mount them inline with the guard rails.
Brgds,
Maurizio
Posted By: Mark&Catherine
Date Posted: 04 September 2013 at 13:28
Hi Richard, If i was going to have a binimi with solid supports I would just get one covering the wheels and ending before the end of the boom like this. They do thi sall the time in Oz, and you can sail with them up. Otherwise go for a pole binimi if you just want shade when not sailing, because all this needs is a zip in th eback of the spray hood
PS sorry everyone its not a hanse, its just modelling a binini!
Date Posted: 05 September 2013 at 11:26
Here is my bimini solution, sorry for the bad quality:
I have two parts folding against the backstay, each are packed individually in a protective cover:
This version allows comfortable seating in the "corners". The sliding mounting on the deck sides allows that you raise the bimini, when folded away, so that you can comtortably stand under it. The boom is only 1.8 meter above the cockpit floor ( and I am 1.9 m long ). I can move the whole folded back to 2 m, can stand when sailing and have free view for harbour maneuvres. Price was about the same as ex factory.
Sorry for the distorted picture, in reality it is much nicer looking ! Can anybody tell me how to avoid this?
Posted By: Silver
Date Posted: 05 September 2013 at 13:07
Ciao Frank,
this one looks definitely better, I though you got stuck with the standard one.
After modifying the rear layout, I can now sit in the corners comfortably, but I have no protection when standing behind the wheels; I think I'll look for somebody to add a back section like yours.
Maurizio
Posted By: richz
Date Posted: 05 September 2013 at 21:49
Thank you all for your contributions. I will look around for the best solution once she arrives. BTW Frank, yours looks very nice; is it something customised for your boat or is it a standard product?
Date Posted: 06 September 2013 at 06:47
Richard, this is a solution developped for me by Nauti Sattler in Southern Germany. www.nauti.de.
You can switch the website to English in the lower right corner. It is now in their standard offering.
I especially like the strong hardware ( 30 and 25 mm tubes ) and the perfect fit. You an also order side shades, which might be useful in the med in summer.
I you have more questions don't hesitate to PN me.
Posted By: richz
Date Posted: 08 September 2013 at 19:00
I could not resist! I have been in Hamble today and thanks to the local Hanse dealer I had the chance to visit a brand new Hanse 345 (waiting for next week's Boat Show, I guess). She's gorgeous...here some pictures:
Date Posted: 08 September 2013 at 19:43
Rich, if you have ordered the FCL sails, be aware that the lazy bag as you have seen it in above photos is way too small.
You have to really push the sail in and the zipper is then under high tension. Elvström has made me aware that this is the way to destroy theFCL mainsail.
I would also order the lazy bag locally with a good fitting cover around the mast. It will be cheaper than a new Elvström main sail.
Posted By: richz
Date Posted: 08 September 2013 at 20:02
I would also order the lazy bag locally with a good fitting cover around the mast. It will be cheaper than a new Elvström main sail. |
Hi Frank, I've asked my dealer about the standard lazy bag fitting with the fcl sails and he told me that it is perfectly fitting. I will check again with him but it would be helpful to get feedback from other members who are experiencing the same issue. I will open another thread. Cheers, Richard
Posted By: richz
Date Posted: 19 October 2013 at 14:08
Hi Maurizio, I almost forgot to get back to you on the mast steps thing. For the 345 they are definitively not standard and somehow less important compared to bigger boats. My dealer has confirmed that they will be installed if I require them. Remembering what you said about your dealer I guess that this the approach they take every time. Cheers,
Richard
Posted By: Silver
Date Posted: 19 October 2013 at 22:01
Hi Richard,
fancy that .. today I had to use them for the first time ... So do get them, you never know.
Btw I went out with a weather forecast of 3-4 kts, mentally ready for a snooze, but soon got 17-18 - quite nice with my 345
Bye,
Maurizio
Posted By: richz
Date Posted: 20 October 2013 at 12:47
Lucky you...I really can't wait!
I have found this
It's a bimini top from NV equipment which apparently covers only the helm's area, behind the boom hence it doesn't create hassle when sailing; but it has a comfortable extension that covers the rest of the cockpit when mooring.
Has anyone had any experience with NV equipment?
Date Posted: 20 October 2013 at 14:41
This looks like a sensible idea, better than a full cover
