Race #1:
May 27, 2013, dist. 7.7nm, courseWK2X, winds WSW 8-15. Gemini was 2nd
across the line, but corrected to 5th place with our initial PHRF
rating of 108. Crew was myself, my co-owner Rob, our wives and my twin 5yo
boys. Although we were short-handed, and failed to get the course down at
the start, I thought we performed considerably well for our first race with NO
modifications to the boat other than the racing bottom and using the stock
Dacron cruising sails (including the self-tacker). Pointing was a bit of
an issue versus other boats, as we were sailing 5-10degrees lower than my
competition. I learned later to ‘inhaul’ the self-tacker 6-8” from the
end of the track for max pointing. It might have helped if I could have
completed a jibe in the last downwind leg but I called it off when I saw my
boys asleep in the cockpit. PHRF rating at this time was 108. We were
correted over by boats in the 138 to 165 range.
Race #2:
June 12, 2013, dist 3.5nm, course M-C-H-X, winds WNW 7-10kts at the start, but
died. Gemini finished DFL (4th place) against a fleet of
larger boats (42-45ft so more LWL) and one liter race boat (Bene 367
first). Though we had a good start, and kept up ok through the first leg,
we couldn’t keep up with the bigger boats on the reaching legs with our stock
sails. On the last downwind leg, the winds dropped below 6kts and the
boat basically parked. We finished 6mins 15secs behind 1st and
2mins 20secs behind 3rd.
Race#3:
June 16, 2013, dist. 5.2nm, course WKMGMX, Winds SW 6-11 (closer to 6 and
liter). Gemini finished DFL again out of 5boats. We got ‘horizoned’
by an Express 37. I have learned if the winds drop below 6kts, especially
with the self-tacking jib, just crack open the beer and start drinking.
Race#4:
July 4th, dist. 6.1nm, course WMWMYX, Winds SW 8-13kts: 4th
of 5 boats. Again, we did not get the course down which really hurt us,
but struggled to compete against other liter race boats with more sail
area. Still had trouble pointing as well as boat speed under the
self-tacker. Finished 3rd non-corrected.
Race#5:
July 24, 2013, dist. 3.46nm, course M-T-L-X, winds N6-8kts: 5th out
of 7 boats.
Race#6:
July 28, 2013, dist. 6.5nm, course WD2X, winds SE 5-9kts (closer to
9kts). Our new Quantum Fusion MR5000 racing sails arrived (main and 145
genoa)!!! The traveler is installed along with the new genoa
tracks. Gemini finished 2nd out of 6 boats!!!
Conditions were near perfect for our brand new 145 genoa and the crew performed
well.
Race#7:
August 4, 2013. dist. 6.8nm, course DGHDHX, winds NNW-W 6-16ths. Gemini
finished 4th of 6 boats with PHRF our rating of 105 even though we
were 2nd across the line. Winds were shifty and up and down,
so we were overpowered at times with our 145 genoa up.
Race#8:
Aug 7th 2013, 3.3nm, W-J-M-X, winds SE 10-11kts, Gemini finishes 6th
of 7 boats 1min 30secs behind 3rd place.
Race #9:
Aug 18, 2013, dist 4.4nm, winds ENE=ESE 6-9kts, Gemini finished 1st
on a corrected basis with our new PHRF rating of 120 out of 4 boats, 6 seconds
ahead of the Bene 36.7 that won every other race and placed 2nd this
time. Now the other skippers are really grumbling about our new PHRF
rating.
Race#10:
Aug 21, dist. 3.2nm, course W-J-M-X, winds S @ 10kts, 1st place of
13 boats. PHRF rating had been changed to 120 putting Gemini in to our
club’s Division 2. Winds were perfect for 145 genoa and two great
reaching legs. We were 1st across the line and tied for 1st
place with a Metalmast 30 on corrected basis. Finished just ahead of a
Farr 33 also rated 120.
Race #11:
August 25th, 2013, dist 6.3nm, course GPITW1, Winds SSE
7-11kts. Gemini finished 3rd of 5 boats on corrected basis and
3rd non-corrected as well behind the Bene 36.7 and NY 36 race boats.
Race
#12:
Aug 28th. Started but abandoned due to lack of wind. We
probably would have finished close to last given the very light winds had the
race not been abandoned.
Race
#13
September 2nd 2013, dist 5.2nm, WN2X, Winds SE. Finished 4th
of 5 boats. Corrected and non-corrected. Winds were a little
heavier, and we attempted to race with our 145 genoa and main reefed upwind
which left us a bit over powered at times.
Race
#14:
, September 22nd 2013, dist 7.8nm, WH3x, Winds NW 10-22kts. 1st
across the line, but 2nd place corrected. Beat out on
corrected basis by a Sabre 34 with a 165 handicap rating vs. Gemini at
120. Winds were heavy and ossiliating up and down. Used the
self-tacker as #3 jib which proved smart move given the heavier winds.
Did not reef the main, which at times left us over-powered upwind.
Race
#15,
October 12th, 2012. The 58th annual Indian Harbor Yacht
Club “Gearbuster” Race - Dist 20nm (Greenwhich to Eaton’s neck and back), Winds
15-30kts, Class 5 – PHRF Non-Spinnaker 120 and under. A “Gearbuster for
the Ages”. Gemini finished 2nd of 9 boats both corrected and
non-corrected. The weather was rough with winds typically ranging between
20-30kts and waves over 6’ in Long Island Sound. One boat was DNS and two
more were DNF. We had our new 109% jib with vertical battens that proved
perfect for the conditions and reefed the main for the upwind leg. 1st
leg was a long beat. We had a rough start not hitting the line right
after the gun, and started on port tack with a starboard tacker hunting us down
from the other side of the line. Although tactically it would have been
better to duck, given the conditions I thought it was safer seamen move to
tack. We found out later we were protested, but prevailed in the
hearing. Once we tacked back out the J100 was WAY ahead, and the Tripp 37
about 10-20 boat lengths ahead. That said, we slowly and methodically
reeled them back in. Down wind, we shook out the reef in the main and
hooked up the wisker pole. Not an easy task in 20+kts of wind and surfing
down 6+ ft waves. As we approached Greenwich harbor we caught up to the
Tripp37, overlapped them about a 0.5nm from the finish and just edged them out
at the finish. We were 8mins 7 secs behind on the J100 corrected
basis. The crew got a real workout and did terrific. The 109% jib
was a great addition to the sail inventory, and should work well up to 25kts
true. Above that I’ll use the self-tacker. Above 20kts, I believe
the main must be reefed upwind. For more interesting commentary, checkout
http://www.indianharboryc.com/default.aspx?p=.NET_ArticleView&qfilter=&tview=0&itemID=303213&chgs=&ssid=273876" rel="nofollow - http://www.indianharboryc.com/default.aspx?p=.NET_ArticleView&qfilter=&tview=0&itemID=303213&chgs=&ssid=273876
which has some pretty good footage from some other boats.
Hope my fellow Hanse racers found this useful. I am looking forward to a much better 2nd year racing Gemini.
James Coffman
