Lost Windows Hull
Forum Name: 430
URL: https://www.myhanse.com/forum_posts.asp?TID=8620
Topic: Lost Windows Hull
Posted By: MarianoAlvarez
Subject: Lost Windows Hull
Date Posted: 10 September 2014 at 11:37
The hull side starboard window were lost this summer in my Hanse 430e assembled in 2007, while I was sailing with 15 knots of wind.
Can anybody tell me, if some one had the same problem, and How was it repaired for don't having the same problem again.
Regards,
Mariano
Posted By: Eduard
Date Posted: 10 September 2014 at 11:41
Check this post:
http://myhanse.com/very-bad-adventure-with-470e_topic7299.html
Ed
Posted By: panos
Date Posted: 10 September 2014 at 15:55
Happened also to us :
http://www.myhanse.com/leaking-windows-again_topic5123.html
Panos
Hanse 630e - selling her -
Posted By: Alain & Anne
Date Posted: 13 September 2014 at 19:00
It did happen to us on our way to New Zealand. Boat has been repaired the same way: acrylic bounded on the hull.
I am thinking of making mechanical fittings to be sure I'll not loose it again!
Here attached pictures:
UHAMBO 430e#004
OCC
Our blog: www.uhambo.fr
Posted By: Peter-Blake
Date Posted: 14 September 2014 at 10:19
Sorry guys,
"Apple" may have found a wonderful description for this opening function ..
But as hanse is not apple, these hullwindows are a bug and not a feature!
Blake 370
Posted By: iemand
Date Posted: 15 September 2014 at 07:30
I think the best replacement will be mineral glass with UV masking (like in car windshields). A good glas supplier will be able to do that  and that will last forever.
The problem is not the UV but the release agent in the Plexi (from the production of the plexi). Thas will come out over the time and release the glue from the plexi. If you want to use plexi again then you should take extruded plexi.
BR Thomas
Posted By: Helios_ri
Date Posted: 15 May 2019 at 02:16
I bought a 2008 Hanse 43e here in the states last year and to my shock the stbd hull window fell right out of the boat.
The fix was installing two new Lewmar windows which come with an aluminum frame. Requires preparing the hull cavity to accept the new frame and screws, but it is a minor effort.
Date Posted: 15 May 2019 at 02:20
The windows that Hanse sent me had this sticker on them. They fit nicely:
Posted By: Lykke
Date Posted: 23 November 2020 at 10:16
Last summer I talked with another Hanse 430 owner who had lost his hull window in rough sea and took in so much water that he lost his electronics before it was discovered.
His window had been repaired by people sent from the yard. I think they had used the Sikaflex system with primer and sealant to glue it in place again. In addition they had added some black UV-tape on outside to protect the glue from the sunlight.
This year when I had the boat on land I used the opportunity to check my windows. (Did not dear to do it on the sea). My windows were completely loose, just held in place by friction and popped out by a light push from a finger.
I contacted the local Hanse dealer and asked what kind of glue to use. They told me that they now had started to use the Tec7 glue which was a relief as this was easy to get hold of. I hope this Tec7 last better than the original glue:
For info: If anyone need to make a new "glass" somewhere in the world, the original thickness is 10 mm:
From now on, it will be on my checklist to give these window a light push when the boat is on land for maintenance and new ant-fouling.
Lykke, Hanse 430e, #8 from 2007
Posted By: iemand
Date Posted: 23 November 2020 at 11:46
you need to replace the acrylic with mineral safety glas than you don't have to worry anymore. With a proper UV cover (black primer from the glas manufacturer) than you are safe.
