Aquair 100
Category: General
Forum Name: Chit Chat
URL: https://www.myhanse.com/forum_posts.asp?TID=8652
Topic: Aquair 100
Posted By: Mark&Catherine
Subject: Aquair 100
Date Posted: 03 October 2014 at 05:58
Hi, in addition to a solar panel, I have bought an aquair 100 towable generator.
Does anyone have one?
In the mounting instructions it is expected that the unit fits between the horizontal bars on the push pit, but on the 385 the bars are too close together so it doesn't fit. Before I invent some complex bracket, has anyone fitted an aquair an come up,with a sensible arrangement?
Posted By: Admirable
Date Posted: 28 October 2014 at 11:19
Hi, I had one on my previous boat and merely strapped the ss ring with two pieces of cord to the pushpit so it was a flexible fit and the generator part sat in the centre of the ring on the swivels. The tension on the tow prevented any rattling of the ring against the pushpit rails.
Hope that help.
P
Songbird
470e
Date Posted: 28 October 2014 at 14:24
Thanks, we have used dyneema strops so that as the tow pulls, the ring is pulled a little way from the pushpit and can swing about 30 degrees, will try it and see
Date Posted: 28 October 2014 at 17:17
if you have tried it out you will have experienced how difficult it is to retrieve with the tow line becoming twisted as the prop keeps spinning.
I used a plastic funnel split lengthwise which l then placed over the towline and fastened with a couple of velcro tabs, narrow part facing the direction of travel. This then slips down the tow line under the water and down to the prop. As the funnel now stops the water flow over the prop, it's easy to retrieve the tow line without it twisting, simple!!  You may have already tried it. Good luck.
P
Songbird
470e
