furlstrom on a 345
Forum Name: 345/348
URL: https://www.myhanse.com/forum_posts.asp?TID=8908
Topic: furlstrom on a 345
Posted By: richz
Subject: furlstrom on a 345
Date Posted: 13 March 2015 at 19:47
Hi All, I am adding a furling gennaker to my 345, the elvstrom furlstrom.
My 345 has the selden mast fitted with a gennaker/forstay combination box with the gennaker halyard coming out just above the jib's one.
Is anyone using a furlstrom sail with my same selden mast combi box, i.e. without changing the gennaker halyard position?
thank you,
richz
Posted By: richz
Date Posted: 15 March 2015 at 00:46
i am picking this up since nobody has replied and perhaps the purpose of my question wasn't so clear.
elvstrom is saying that the hanse 345 mounting the selden mast has the gennaker halyard exit too close to the forestay and the furlstrom will not roll. they are recommending to move the exit of the gennaker halyard at least 300 mm above the forestay to ensure the furlstrom enough room to roll.
is there anyone who has a direct experience to share?
cheers,
richz
Posted By: alidal
Date Posted: 15 March 2015 at 05:46
Yes, I have to do the same on my H 400 with Selden mast. It was not possible to roll the gennaker with the original halyard.
I cant remember how many mm above, but could be something like 300 mm
I got the exact measurement from Selden.
info@seldenmast.se
Hanse 400#655
Posted By: monty7442
Date Posted: 04 April 2015 at 18:14
We have had our Hanse 345 along with the Furlstrom since new last year. Firstly it a great way to go. Easy and very safe to use and overcomes the relatively poor downwind performance of a self tacking jib.
The Furlstrom comes with a very nice quality furler at the bottom and swivel at the top. We use the standard spinnaker halyard that came with the rig with no problems at all. I cant think how far it is positioned above the jib halyard but it won't be that far. So I'm not exactly sure why Elvstrom are raising this as a particulalr problem to check. I think it will furl fine. The furler at the foot of the sail will be on the eye on the end of the step so that is taking the angle some way from the jib.
You will need a Bobstay on the step platform as the loads are high especially close on the wind.
By the way I have tried running the sheets on the inside and outside of the jib and would recommend outside (the long way round) works best. Or you can furl/unfurl before /after the gybe.
I hope this helps.
Monty
Posted By: richz
Date Posted: 04 April 2015 at 19:31
Many thanks for your feedback.
I am going to have a try with the standard configuration before making any change.
Nobody raised the problem about the bobstay though; is that really necessary?
How big is your gennaker?
Thanks again. Cheers.
Date Posted: 05 April 2015 at 00:06
I think the Bobstay is essential. Inspiration Marine recommended it and I agree. I'm not actually sure the size of my Furlstrom, it's big enough when up! But it will be the standard size Elvstrom recommend for the 345. I think the Bobstay was about £400 but well worth it. Imagine the damage it would do if it rips the step/deck up (which without the support it will probably do sooner or later).
The forces are actually greater at the lower wind speeds because firstly you will be able to sail closer to the wind with the resulting sideway forces and also your boat speed will be further from the wind speed.
Monty
Date Posted: 05 April 2015 at 00:20
By the way we also have the Selden mast. Also somewhere on the forum there is another thread about using the Furlstrom I put some other tips on, it might be worth trying to find it.
Enjoy using it. The season gets under way soonSmile
Monty
Date Posted: 05 April 2015 at 10:45
We have the Z-Spar on our 345. When I talked to the local Elvström loft their statement was pretty clear:
a) Furling Gennaker:  You do not need a bobstay, the current bowsprit can take the load
b) Furling Code 0:  You must use a bobstay, loads are higher than for a gennie, the bowsprit is too weak.
Hope this helps.
BTW: I am very happy with my furlström, especially in the prevailing light winds here in Summer
Posted By: richz
Date Posted: 09 April 2015 at 20:59
Quick update: I have been told that the yard is now delivering the 345 with the bobstay and that installing it is highly recommended if you intend to use a Gennaker.
Posted By: 415 Singapore
Date Posted: 15 April 2015 at 09:35
Hi we have a furlstrom on our 415 and haven't had any issues with it all. We have recently bought a Code 0 though and would like to fit a bob stay, does anyone know if there is a fixing plate moulded into the stem to fix the base plate to, or have any recommendations as to how to fix the base plate to the stem.
Thanks in advance
Paul - Night Train
Paul - Night Train - 415 #136
Posted By: Pepote
Date Posted: 12 May 2015 at 17:12
Hi everybody,
At the "H345 Owner's Safety Manual" says that the max spin gennaker height at 13.680 meters of the mast base (760mm above FH). For the code zero it is 530mm above FH.
Regards.
Jesús
Jesús
Posted By: richz
Date Posted: 13 September 2015 at 14:44
Hi All,
I didn't have the chance to post my final feedback on this thread.
Eventually I decided to have a try with the standard mast configuration (i.e. without moving the gennaker halyard higher on the mast) and it proved to work perfectly well. I added a bobstay, though (as advised by the yard).
Here it is in all its beauty Tongue:
Posted By: ccharlie
Date Posted: 14 September 2015 at 11:36
I am new -  owner since july - with  Furstromer. The gennaker halyard position was changed (on my request) conform specifications Hanse gave to my dealer and Elvstrom. The halyard is lead down to a ring aprox 20 cm lower than the block.  It works well,  gr., Frank
Posted By: ccharlie
Date Posted: 14 September 2015 at 11:50
A question about the bobstay connection:
Is your bobstay also attached like on the pictures ?
I would have attached it to the ring in the middle.
gr., Frank
Posted By: richz
Date Posted: 15 September 2015 at 08:05
Hi Frank,
I have a 2014 model; I think the yard introduced the rings only recently.
Here is how they fixed the bobstay:
Posted By: Silver
Date Posted: 22 September 2016 at 21:59
Hi all;
I'm requesting quotations for a Furlstrom, as everyone seems quite happy with it; as I've seen specs showing 68 or 76 m2, I would like to ask those, like Frank f.i., that have it on their 345, what the actual size is, and if the furler is the Bartels FE III L.
Besides, does the Furlstrom arrive 100% ready to be mounted, or is anything left out that needs to be purchased ?
Finally, I would appreciate if someone could send me a PM with pricing info - I imagine it could be against forum policy to post figures.
Brgds,
Maurizio
Hanse 345 # 51 Performance sails Volvo D1-30 KiwiProp Coppercoat
Posted By: Leo
Date Posted: 30 January 2018 at 20:29
Hi Maurizio, Hello everybody,
would love to pick this up:
  • did you end up with the Bartels FE-III ?
    • Somehow I am always offered the FE-II, although it's only for up to 70m² and the Furlstrom is 76m²
  • does anybody know whether its necessary to change the mast configuration with the Z-Spar mast?
  • did anybody not buy a furlstrom, but a different sail? I just wonder how hanse specific the furlstrom sails are and whether other "standard" gennakers of the same size work just as well
Best regards,
Leo
Posted By: Silver
Date Posted: 02 February 2018 at 21:56
Hi Leo, all concerned;
no, eventually I got a Selden CX 15 and a Quantum 66 m2 gennaker, an all around sail very close to the furlstrom; for the latter I had an offer with Bartels Fe-III, the Fe-II is in fact a bit under specs.
I have to admit that a major reason for me to choose the Quantum is that my boat is moored very close to their loft, which should help for future support if needed, and also got a noticeable price difference.
On the whole I'm happy of what I bought; the sail has a large working range; maybe I don't run as fast as others on light winds, but this may be me 😔 and the slightly smaller size and thicker cloth: 150 vs. 100.
I was not so happy with the way a reinforcing velcro was placed, though, but this is less important.
The Selden furler works very well; just not very easy to unlock the AT cable from the drum, so I normally pack it all together.
I have the Z-Spar mast and did no modifications.
I added a short bowsprit with stainless steel bobstay; a nice and tough design from Gold Service Rigging; I always prefer to stay on the safe side.
Safe winds to everyone!
Date Posted: 03 February 2018 at 10:42
Hi Folks,
I have the standard Elvstroen furlstroem on my 345 since 2014. Very pleased with it, as we are sailing mostly in light wind conditions ( bft 1-3 ). However I noted that my standard bowsprit was slightly bending upward when you pulled the halyard tight with the electro winch. I have therefore added a bobstay consisting of a threaded eye replacing the lower screw of the stainless bow attachment, a stainless spanner and an eye below the bowsprit. I have the feeling that I can point higher with this attachment, clearly this set up avoids the flex of the "bowsprit".
Posted By: Leo
Date Posted: 03 February 2018 at 17:06
Dear Maurizio, dear Frank,
thanks a lot for your answers. They are very helpful indeed - and we will make sure that we reinforce the bobstay. Also my Hanse dealer reassured me that there is no need to change the mast configuration with the Z-spar mast, but it is recommended to get a Harken (Fallabweiser in German, not sure whether that's translated correctly ;-)).
Good to hear that the Furlström goes in light winds, because that's what we want to have it for and other (cheaper) options are mainly made of fabrics that have double the weight per sqm...
